Vvti bpu+
Mike2JZ
Engine Type
  • JDM TT 2JZGTE VVTI Supra Engine
Engine Spec
  • Stock, unopened
Turbo(s)
  • Stock Jspec's running in TTC
Modifications
  • Walbro 255 @ 13.5v
  • AN6 Fuel Lines. Fuel pulsation dampener bypassed
  • AEM Universal Adjustable Fuel Pressure Regulator
  • Injector Dynamics 1050x Injectors + Top Feed Fuel Rail
  • Custom 3'' downpipe back exhaust
  • Superspark Ignition Coils (Wasted Spark setup)
  • Whifbitz 4'' Intercooler Kit
  • HKS Air Filter
  • Oil cooler
  • 3 Port boost solenoid
Fuel Used
  • Tesco 99
  • AFR target of 11.5 whilst boosting.
Transmission
  • R154
  • Power run performed in 4th gear
ECU
  • Link Extreme Wire In ECU
  • VVTI system tuned
  • Factory e-throttle system tuned
  • Traction control tuned
Dyno Used
  • DD @ Hidden Performance
Power figure
  • Recorded 370 rwhp, dyno estimated 435hp at flywheel.
  • 450 Ft.lbs estimated of torque @ flywheel
Boost Pressure
  • Peaks at 1.2 Bar, tapers between 1-1.1Bar after.
Notes
  • This Supra is planned to be a track car. Map is fairly conservative with timing to see how it reacts whilst being hammered on the track and getting hot.
  • Further power gains expected to be had once data from track has been recorded. Hopefully the twins last through the ordeal :p
Edited by Mike2JZ (see edit history)
