Trd Oil filter or not
jza800
Hi
I have searched the internet long time now, to find something out with the Trd oilfilter, is it worth the money or not? i now there is a lot of opinions about the filter, many say it is a good filter other say stock.. I would like to hear good or bad
it is this filter i am looking at..
TRD SPORTS OIL FILTER 90915-SP020
If anything i'd use a K&N Pro one. simply because they have the socket head on the end of it, easier to remove and tighten.
Probably the same filter inside.
This, and simply because of the socket head
- - - Updated - - -
I use Blueprints or the black k&n ones. Can be had for less than a fiver. The white k&n ones are pointless with that useless spanner thingy. Id recommend blue prints for the price they are very high quality. Higher than k&n.
The old version of the Oem Toyota/Lexus V8 (Japan made one, not the new ones which are from China) oil filter uses similar kind of filter element inside of the metal core than the TRD 90915-SP020 filter uses. New Oem Toyota Supra oil filter has different, like normal paper element inside. Please take a look of these MKIV.com articles.
Toyota oil filters – Toyota 90915-20004 vs. Toyota 08922-02011 vs. Mobil1: http://mkiv.com/techarticles/parts/toyota_filter/index.html
TRD oil filters – TRD USA vs. TRD Japan Oil Filters: http://mkiv.com/techarticles/parts/toyota_filter/trd_filters/index.html
I know these articles are old but I hoared the original Japan made 90915-20004 filters while these were available and also some TRD 90915-SP020 filters as these two has quite similar style filter elements inside.
Edited by Mika (see edit history)
