mikewoods Posted March 16, 2018 Share Posted March 16, 2018 Im a newbie to please be nice, I have a W58 currently and getting to ready want more power. After reading post after post on best route to go down i have decided on a 2JZ-GTE Engine with R154 gearbox. I have found a gearbox that i want to but today but before i make the plunge just wanted to check its the right one https://www.jdmdistro.com/shop/engines/toyota-r154-1jz-2jz-manual-transmission-5/ Is this the correct one? I have read that some need a shifter extension and its a lot harder to fit. Is the one i have found the best one to go for? thanks in advance Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 16, 2018 Share Posted March 16, 2018 That one is a direct fit as it has the remote shifter housing, so no need to extend anything with that. Link to comment Share on other sites More sharing options...
mikewoods Posted March 16, 2018 Author Share Posted March 16, 2018 thanks mate, so all i need is the front prop from a mk3? clutch and flywheel? Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 16, 2018 Share Posted March 16, 2018 Flywheel, Clutch, Release Bearing, Slave Cylinder, MK3 Front Propshaft. Link to comment Share on other sites More sharing options...
mikewoods Posted March 16, 2018 Author Share Posted March 16, 2018 Thanks Mike, is the flywheel i need one for a w58 or r154? Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 16, 2018 Share Posted March 16, 2018 mikewoods said: Thanks Mike, is the flywheel i need one for a w58 or r154? You will need a R154 flywheel. Normally found on 1JZGTE. W58 one looks similar but size is different. Link to comment Share on other sites More sharing options...
mikewoods Posted March 16, 2018 Author Share Posted March 16, 2018 You sir are a legend!! thankyou very much Link to comment Share on other sites More sharing options...
