Thomas.B Posted March 14, 2018 Share Posted March 14, 2018 Hi! So am just about to order new rims and I'm going with Jr21 8.5" front and 9.5" rears 19 would be with 235/35 front and 265/30 rear. 18 would be with 235/40 front and 265/35 rear. Would ideally want wider rims but they only come in these widths and 11" and that won't fit sadly. What would you choose? I want to fill upp the wheelhouse nicely without the tyres rubbing anywhere. Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 14, 2018 Share Posted March 14, 2018 What would you choose? I want to fill upp the wheelhouse nicely without the tyres rubbing anywhere. The offset can have a big effect on the look too? If you are retaining the rear arch inner lip then to get the look most people like, filling the arch and being close to inline with the bodywork when looking from the front or back, then close attention to the offset is crucial. 265 isn't so wide at the rear so the offset may be ok at 30mm possibly even less? 9.5" rear stock 17's are 50mm and sit too far in for looks in most peoples eyes. Too low an offset and you risk it looking good/ok but the tyres rubbing on the arch lip (hence why lots of people 'roll' their arches). You obviously have no inner arch rubbing/clearance issues. Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 14, 2018 Share Posted March 14, 2018 This thread could be helpful? http://www.mkivsupra.net/vbb/showthread.php?211133-Wide-Wheels-and-Agressive-Offsets&highlight=offsets Quote Link to comment Share on other sites More sharing options...
Style Posted March 14, 2018 Share Posted March 14, 2018 I prefer 18's There are a couple of styles of 19's that don't look too bad but for the most part they just look too big to me. A well sized tyre on 18's will fill your wheel wells quite nicely Quote Link to comment Share on other sites More sharing options...
Big Mark Posted March 14, 2018 Share Posted March 14, 2018 I have JR20's on my car. I had to go for 19s to clear my front brakes. Probably would of gone for an 18" on rear with more tyre sidewall but they only do the 11J in 19" diameter. I got mine from jdmdistro.com and if you go on their website you can see sizes, but also custom offset range that is available. I went 9.5J fronts et37 which fit fine but room for a 5+mm spacer, 255 tyre at present. And rear is 11J et35 (max et they do) which meant rear arches needed flaring so that I could get an 305 rear tyre to clear. . Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 14, 2018 Author Share Posted March 14, 2018 Sorry the ET's available are: 18" 8.5" ET 20 or 40 19" 9.5" ET 22 or 40 Thanks for the help! I suck at rims apparently lol Quote Link to comment Share on other sites More sharing options...
squiffy Posted March 14, 2018 Share Posted March 14, 2018 18's if you have a stock body and 19's if you have a bodykit imo. I sometimes think my 18's look a bit small against my kit Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 14, 2018 Author Share Posted March 14, 2018 I have OEM front with a carbon lip with ridox sides and spats. What ET to go for? Quote Link to comment Share on other sites More sharing options...
evinX Posted March 14, 2018 Share Posted March 14, 2018 18s without dish, 19s with dish Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 14, 2018 Share Posted March 14, 2018 I have these if you're interested? Fronts would protrude by 10mm, but they certainly clear big brakes and it wouldn't take much to roll the arches to suit. They are the perfect stock body size/offset for the rear. http://www.mkivsupra.net/vbb/showthread.php?336357-WedsSport-SA-67R Shipping wouldn't be an issue either. Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 14, 2018 Share Posted March 14, 2018 I have OEM front with a carbon lip with ridox sides and spats. What ET to go for? 40mm would probably be consider to 'into' the arch, it's only 10mm more sticking out than a stock 17" wheel, definitely won't rub. 22mm could make it close to rubbing the lip as it's 28mm further out than a stock 17", but with your 265 tyres could be ok without any arch work, it is hard to say specifically unless someone has a 9.5" with that or very close to that offset. Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted March 14, 2018 Share Posted March 14, 2018 If you go 18" or 19" the rolling diameter will be much the same regarding filling the arches, unless you don't mind your spedometer being 10% or so out. My wheels have that concave design also and I went 18" for ride quality and traction. Very good site to calculate what wheel and tyre combo will keep your spedometer accuarate: http://www.willtheyfit.com/ This is the standard Supra wheel and trye setup. Front - Alloy 17 x 8j +50, Tyre 235 45 R17 Rear - Alloy 17 x 9.5j +50, Tyre 255 40 R17 Here's a tyre guide for what width is ideally suitable: https://www.tyres-pneus-online.co.uk/tyre-equivalence-advice.html Here's another thread where rolled arches and maximum offsets were discussed: http://www.mkivsupra.net/vbb/showthread.php?267184-Maximum-offsets-on-rolled-arches Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted March 14, 2018 Share Posted March 14, 2018 Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 14, 2018 Author Share Posted March 14, 2018 There is 11" too but only with ET 25 I think I'm going with the 19's as I think the total look would be better with the kit. But ideally I'd want 19*11 on the rear but with ET 25 would that even be possible? My tyre guy says it would be highly likely it would rub.. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted March 14, 2018 Share Posted March 14, 2018 Sorry the ET's available are: 18" 8.5" ET 20 or 40 19" 9.5" ET 22 or 40 Thanks for the help! I suck at rims apparently lol As I've already said you can actually get these in a custom offset within a stated range. Cost is €15 https://www.jdmdistro.com/?product_cat=&s=jr21+custom&post_type=product Quote Link to comment Share on other sites More sharing options...
formatzero Posted March 14, 2018 Share Posted March 14, 2018 I think 19 for look,i had Jade r's on mine thought they looked great,but maybe handling is better on smaller sizes. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted March 14, 2018 Share Posted March 14, 2018 Purely for looks - 19s without a doubt. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 14, 2018 Share Posted March 14, 2018 Here's a few shots of mine with my various wheel choices during my ownership. The first image is the latest, with the current 19" wheels fitted. Personally for aesthetics I think they look the best. The other two are both 18" wheels, but it'll give you an idea of the difference between solid black, or a polished lip, and how that affects the look. Being honest, I didn't notice much difference in handling or comfort going from 18s to 19s, however, I had tein coilovers fitted with the 18s, and went back to stock shocks with lowering springs when I fitted the 19s Quote Link to comment Share on other sites More sharing options...
squiffy Posted March 14, 2018 Share Posted March 14, 2018 I go by the statement "It's not about making your wheels fit the car, it's about making your car fit your wheels" [emoji16] Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 14, 2018 Author Share Posted March 14, 2018 Mark: thanks I have emailed my guy to see if he can fix it Mk4Gaz thanks alot! It'll be 19's and your pics helped me Thanks alot everyone! I'm just gonna try to get 10-11" wide with 285-295 back tyre, that would be ideal for me. These rims are purely for daily drive/play, I have a set 18" for track. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 14, 2018 Author Share Posted March 14, 2018 Double post Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 15, 2018 Author Share Posted March 15, 2018 What ET would be good rear for a 285-295 tyre and 10,5-11" wide rim? 15-40 is available. My tyre guy said that the wholes in the rim would be drilled after paint in this case... Would that be visible when bolts are on? I think no as the bolts would cover this? Quote Link to comment Share on other sites More sharing options...
