SRD AC Delete bracket
Lee P
We now do a billet version of our AC delete brackets
These are needed to brace the Power steering pump once the AC is removed.
Billet one can be mounted either way round depending on preferred look.
It has steel inserted to aid strength around the mounting points. Works with stock bolts.
Now available in the on line store and can be purchased with the shorter belt needed.
We also still do the steel version.
The 6 speed aux tensioner damper needs to be removed when deleting AC compressor.
https://www.srdtuning.com/product/srd-ac-delete-brace/
