peter richards Posted March 7, 2018 Share Posted March 7, 2018 hi guys need to change the filter, oil is good was changed last year but not used the car , got the car up on the front , so will I have to take the plastic undertray off to get to it Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 7, 2018 Share Posted March 7, 2018 It's a bit of a squeeze but it can be removed without needing the jack the car up. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 7, 2018 Share Posted March 7, 2018 Move the PS tank out of the way and you can access it from above. Quote Link to comment Share on other sites More sharing options...
peter richards Posted March 7, 2018 Author Share Posted March 7, 2018 I wanted to get it up on the front as I have a tiny oil leek , probably after changing the gear box oil , and when I was under I thought how am I going to reach the filter , frank has it got to be removed or just moved, although saying that its not red Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 7, 2018 Share Posted March 7, 2018 (edited) Just unbolt it and move it out of the way, if you need to do a fluid change you could remove it altogether and give it a good clean inside. E2A Just be careful not to damage the fragile screen/filter inside. Edited March 7, 2018 by Frank Bullitt (see edit history) Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 7, 2018 Share Posted March 7, 2018 Peter x3 10mm bolts to free the reservoir up, you may need to unclip a bit of loom to get to one (you just need to insert a screw driver into part of it and lift. With the reservoir loose you can move it enough (without disconnecting any fluid lines) to create a gap big enough to get your hand down/filter out. Loosening the filter from underneath isn't that easy from memory, you need some height to get your arm up there which isn't easy with jack and stands. Quote Link to comment Share on other sites More sharing options...
peter richards Posted March 7, 2018 Author Share Posted March 7, 2018 ok guys thanks , ive changed all the PS fluid , last year with the oil , diff , gear box . just couldn't reach the filter , then didn't use the car as work was manic , I wanted to do a good clean up on the under side but I cant get it high enough in my garage , needs a good wire brushing and some paint Quote Link to comment Share on other sites More sharing options...
