Thomas.B Posted March 6, 2018 Share Posted March 6, 2018 Been searching some but I'd like to doublecheck before I order. Been looking on 19" for my Supra as the 18" that are on now will be for track use. Car doesn't have rolled arches and I just had it resprayed so that won't be happening Anyways: Front: 19" 8.5" ET 35 or 20 (?) Rear: 19" 9,5" ET 35 or 20 (?) Will these work? Is 9.5" on the rear a little on the small side? What tire width would I be able to fit without rubbing? Thanks! Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 6, 2018 Share Posted March 6, 2018 You might get away with a et20 on the front, an et35 might foul the brake calipers, depending on the wheel design and whether you're uk or jspec brakes. Et35 will fit the rear, but an et20 will definitely rub. My wheels are 8.5f et25, and 9.5r et30, and mine only just clear the front uk calipers. I did have the rears at et25 and they rubbed Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted March 6, 2018 Share Posted March 6, 2018 Mine is Front 19 x 9.5 +22 tyre cant remember but I think its 245/35/19 Rear 19 x 10.5 +22 tyre is 275/30/19 I have no front rubbing issue The rears on mine was rubbing a little and only on bumpy roads so I had them rolled but if you have adjustable coilover's maybe you could adjust the damper and have harder ride for it to stop rubbing ? Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 9, 2018 Author Share Posted March 9, 2018 Thanks for the input! Would 19"x11 fit with et25? Quote Link to comment Share on other sites More sharing options...
Big Mark Posted March 9, 2018 Share Posted March 9, 2018 Thanks for the input! Would 19"x11 fit with et25? No. I have 11j et35 rears and had to flare out the rear arches, an et25 would stick out 10mm further still. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted March 9, 2018 Author Share Posted March 9, 2018 I never get a break lol thanks! Quote Link to comment Share on other sites More sharing options...
