Lee P Posted March 2, 2018 Share Posted March 2, 2018 Exciting news at SRD After almost two years of planning we have finally put the order in for our dyno. We have started building the dyno cell and hope to be up and running later this year. Once installed we will be able to offer mapping and diagnostic services in house. Will also be offering fitting and mapping of a large range of ECU’s from Syvecs, Link and Motec. Will update with progress as we go but here is some info on the dyno. MODEL 424X LC2 The 424xLC2 features 2 x 24" knurled, precision balanced drums, 2x Eddy Current Load Absorption Units, measures up to 2000 HP, 2000 FT LBS, 200 MPH, and is capable of 1600HP peak absorption (in AWD) making it the most powerful load control dynamometer on the market. Unlike inferior non adjustable wheelbase designs, the model 424xLC2 can adjust wheelbase with a push of a button from 88” to 140”. This allows the tires to contact the rollers evenly and in conjunction with the large drum diameter the 424xLC2 provides a virtually flat, stable surface for tire contact eliminating unnecessary tire slippage and deformation. The result is precise, repeatable data every time. The 424xLC2 can operate in “inertia only” mode for assessing gains from minor bolt-on modifications, or utilize the duel eddy currant load absorption units for advanced load testing. Load tests include step, sweep and custom road-load profiles in all gears and at any throttle position. This system also eliminates any potential speed bias between the two drums when using the Dynojet speed balance feature. Horsepower and torque are measured at each drum and can be displayed and/or logged independently or combined. This feature allows you to assess the vehicle’s power-split and can also aid in troubleshooting drive-train issues. With the addition of the optional Linx System, the 424xLC2 allows you to test modern AWD vehicles without the fear of potentially damaging the center differentials, or activating intrusive stability control systems. It is also useful for those 2wd performance vehicles that require all four wheels to be rotating in order to avoid "reduced power mode’’. MODEL 424XLC2 STANDARD FEATURES AND EQUIPMENT Measures 2,000+ HP / torque and up to 200MPH Tests vehicles in either two-wheel or all-wheel drive modes, bi-directional rotation Consists of two Model 224x chassis dynamometers PowerCore software suite with WinPEP 8 to interface DynoWare RT dynamometer electronics and hardware 2 channels available for Automatic Conditions Measurement (absolute pressure, air temp, humidity) 1 sensor included 4 Analog Input Channels for 0-5v sensors (sensors and cables not included) 14 expansion ports for DynoWare RT accessories and DJ-CAN devices Pit or Above-Ground configurations. Air Actuated Brake System 10 button sample pendant for software and dyno control Ignition wire inductive tachometer pickup leads Electronically controlled wheelbase adjustment from (standard 88” to 130” or optional 98” to 140” Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 2, 2018 Share Posted March 2, 2018 Sweet thats gonna be a nice addition! Link to comment Share on other sites More sharing options...
MRX Posted March 2, 2018 Share Posted March 2, 2018 Awesome news! Link to comment Share on other sites More sharing options...
mellonman Posted March 2, 2018 Share Posted March 2, 2018 dyno open day ?!?!?! Link to comment Share on other sites More sharing options...
Swampy442 Posted March 2, 2018 Share Posted March 2, 2018 The final piece of the puzzle Link to comment Share on other sites More sharing options...
mattdavies Posted March 3, 2018 Share Posted March 3, 2018 dyno open day ?!?!?! What he said. Got some figures on the power board Link to comment Share on other sites More sharing options...
Tyson Posted March 3, 2018 Share Posted March 3, 2018 Sounds like an impressive piece of kit ! Link to comment Share on other sites More sharing options...
Chris Bailey Posted March 3, 2018 Share Posted March 3, 2018 Awesome Lee! Will you do an open day when it’s up and running? Link to comment Share on other sites More sharing options...
T2 MSW Posted March 3, 2018 Share Posted March 3, 2018 Awesome bit of news that Lee, Really pleased for you Link to comment Share on other sites More sharing options...
novak Posted March 3, 2018 Share Posted March 3, 2018 Will my car be mapped on this in late April? Link to comment Share on other sites More sharing options...
mplavery Posted March 4, 2018 Share Posted March 4, 2018 So dyno day and BBQ for the summer then Link to comment Share on other sites More sharing options...
