blythmrk Posted February 25, 2018 Share Posted February 25, 2018 Ok I have tried for around an hour I have the rear cover of the seat unzipped so I can see and feel inside and cannot feel and button or release clip I have one side moving but the side with the seat belt clip is solid any ideas? I did see something on hear about pressing with a screw driver at the shoulder of the seat I have tried with two of us on it one holding the seat and pulling upon the head rest and the other pressing with the screw driver:banghead: Quote Link to comment Share on other sites More sharing options...
stevie_b Posted February 25, 2018 Share Posted February 25, 2018 Have you seen this thread? http://www.mkivsupra.net/vbb/showthread.php?34510-Headrest-removal Quote Link to comment Share on other sites More sharing options...
blythmrk Posted February 25, 2018 Author Share Posted February 25, 2018 Have you seen this thread? http://www.mkivsupra.net/vbb/showthread.php?34510-Headrest-removal I will give this a go tomorrow i may have been pressing in slightly the wrong place! Thanks Quote Link to comment Share on other sites More sharing options...
achagor Posted February 25, 2018 Share Posted February 25, 2018 I've been taking my off recently to put new leather covers on, and tried all the above guide without luck, and eventually figured it out. Here's my interpretation of the procedure, you can do one side then the other, first try and feel the rod that goes into the the back rest, near the outside edge of the hole where the rod goes in, you'll be able to just feel a button, at the same time depress the button with one hand and use your other hand to pull up the head rest on the side you are depressing, you should be able to feel it come up and then do the other side and voila finally the bugger comes off lol. Hope it helps mate! Quote Link to comment Share on other sites More sharing options...
achagor Posted February 26, 2018 Share Posted February 26, 2018 <a href= Quote Link to comment Share on other sites More sharing options...
blythmrk Posted March 1, 2018 Author Share Posted March 1, 2018 I've been taking my off recently to put new leather covers on, and tried all the above guide without luck, and eventually figured it out. Here's my interpretation of the procedure, you can do one side then the other, first try and feel the rod that goes into the the back rest, near the outside edge of the hole where the rod goes in, you'll be able to just feel a button, at the same time depress the button with one hand and use your other hand to pull up the head rest on the side you are depressing, you should be able to feel it come up and then do the other side and voila finally the bugger comes off lol. Hope it helps mate! It worked a treat thanks Quote Link to comment Share on other sites More sharing options...
