ripped_fear Posted February 24, 2018 Share Posted February 24, 2018 Hey guys second turbo has stopped spooling but it's not the iacv vsv as I have tried ttc and swapped vsv. Anything else to check other than chasing a vac leak. Thanks in advance J Link to comment Share on other sites More sharing options...
Slam Posted February 24, 2018 Share Posted February 24, 2018 not going fast enough [emoji57] Link to comment Share on other sites More sharing options...
Graham1984 Posted February 24, 2018 Share Posted February 24, 2018 slam said: not going fast enough [emoji57] /quote] Link to comment Share on other sites More sharing options...
BOB B Posted February 25, 2018 Share Posted February 25, 2018 Hi Jake, is it making any other sort of noises that it doesn't normally? Link to comment Share on other sites More sharing options...
ripped_fear Posted March 1, 2018 Author Share Posted March 1, 2018 BOB B said: Hi Jake, is it making any other sort of noises that it doesn't normally? All good mate other than that, got a few things to check, exhaust gas valve which i think i have sourced and some vsvs which i have to, just to cold to start wrenching on it - - - Updated - - - Slam said: not going fast enough [emoji57] /QUOTE] Should have known you would comment Link to comment Share on other sites More sharing options...
peter richards Posted March 1, 2018 Share Posted March 1, 2018 don't think ive ever had mine working Link to comment Share on other sites More sharing options...
ben_harmer32 Posted March 1, 2018 Share Posted March 1, 2018 time to go single do the parrell mod. That'll rule out a load of vac lines and some VSVs Link to comment Share on other sites More sharing options...
coza Posted March 1, 2018 Share Posted March 1, 2018 i had issues with this a while back spit vac hose caused it Link to comment Share on other sites More sharing options...
ripped_fear Posted March 3, 2018 Author Share Posted March 3, 2018 peter richards said: don't think ive ever had mine workingWhat?! ben_harmer32 said: time to go single do the parrell mod. That'll rule out a load of vac lines and some VSVsNot happening. And read post 1 tried ttc and didn't help so that rules out the iacv vsv coza said: i had issues with this a while back spit vac hose caused itYeah thought a vac leak could be likely but given them a visual and sprayed it all with soapy water and ran the car no sign of bubbling, could do with doing a smoke test really. Going tbh I haven't attempted to solve it since I posted this thread. To cold to work in the garage for any length of time. Link to comment Share on other sites More sharing options...
jonc Posted March 3, 2018 Share Posted March 3, 2018 ripped_fear said: Hey guys second turbo has stopped spooling but it's not the iacv vsv as I have tried ttc and swapped vsv. Anything else to check other than chasing a vac leak. Thanks in advance J /QUOTE] Hi Jake its been a while Having just changed my turbos I would look at the following ESGV for operation and vac hose for integrity Exhaust bypass on the turbo for operation and vac pipes for integrity VSV. Hear me out mate. I would test the solenoid operates. The vac hose going back to no2 tubby are a pita. I changed all mine for gate hoses when I did the turbo change. If you takes no2 tubby air inlet off you can check the turbo is free to turn but doubt it will be a damaged turbo as you would have heard something. Hope some of this helps - - - Updated - - - ripped_fear said: Hey guys second turbo has stopped spooling but it's not the iacv vsv as I have tried ttc and swapped vsv. Anything else to check other than chasing a vac leak. Thanks in advance J /QUOTE] Hi Jake its been a while Having just changed my turbos I would look at the following ESGV for operation and vac hose for integrity Exhaust bypass on the turbo for operation and vac pipes for integrity VSV. Hear me out mate. I would test the solenoid operates. The vac hose going back to no2 tubby are a pita. I changed all mine for gate hoses when I did the turbo change. If you takes no2 tubby air inlet off you can check the turbo is free to turn but doubt it will be a damaged turbo as you would have heard something. Hope some of this helps Link to comment Share on other sites More sharing options...
peter richards Posted March 3, 2018 Share Posted March 3, 2018 don't go fast enough lol Link to comment Share on other sites More sharing options...
JasonR24 Posted March 3, 2018 Share Posted March 3, 2018 (edited) Alright mate I reckon it’s the exhaust valve, see how you get on with that. Also check the hose behind the engine that goes to the second turbo. Mine was split and did the same thing Edited March 4, 2018 by JasonR24 (see edit history) Link to comment Share on other sites More sharing options...
Rob W Posted March 4, 2018 Share Posted March 4, 2018 Check your EGCV actuator rod is not stuck if your sure your VSV’s are all ok. Link to comment Share on other sites More sharing options...
ripped_fear Posted March 4, 2018 Author Share Posted March 4, 2018 Thanks guys lots of ideas but looks like I may have sorted it. Puffed some smoke into the iacv vsv vac line and loads of smoke appeared behind the plenum. Found a vac line right at the bottom disconnected have plugged it back in and just need to test it now. Link to comment Share on other sites More sharing options...
Graham1984 Posted March 4, 2018 Share Posted March 4, 2018 Does the test involve gunning it down the road? If not, why not. Link to comment Share on other sites More sharing options...
ripped_fear Posted March 4, 2018 Author Share Posted March 4, 2018 Graham1984 said: Does the test involve gunning it down the road? If not, why not.That's exactly the test Link to comment Share on other sites More sharing options...
Graham1984 Posted March 4, 2018 Share Posted March 4, 2018 ripped_fear said: That's exactly the test /QUOTE] That's why is says Tech expert in my sig Link to comment Share on other sites More sharing options...
