2jz gte aristo engine swap advice
Supra374
Hi I’m lookin to buy a non vvti aristo engine and auto box and would love some help on what I need to change and need to get to swap it into my na auto
If anyone has done this swap the help aould be greatly appreciated as I know a good bit about cars but for something like this i am unsure.
So if I have a list off Parts I can start collecting them now for the swap
Thanks
Im here :D
Best and only advice I can give is get a TT Supra wiring harness and ECU. The Aristo engine is the same, apart from the sump and water pump, but everything else, sensors, plugs, switches, all the same. But the Mk1 Aristo has an ECU controlled hydro fan for the radiator, a nitrogen assisted ABS/traction control brake master cylinder which cause lots of problems
Im here :D
So what’s do I have to do there then. Is that on all non vvti aristo engines, I’m I better to go vvti what’s your verdict
