New MKIV owner and forum member.
Gormanator7
Make sure you can get the filler screw undone before draining the diff
I watched a utube video on the transmission. Looks pretty simple. I haven't found one on the diff. I did just download the app so I'll be looking it up there. Yeah it would suck to drain all the fluids and not be able to refill. I bought RP synchro. what are you using on the rear diff?
This is a useful section
http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine
LSD Diff Oil
Stock = Unknown 75w90 Gear Oil
Capacity ~1.5L's (have 2L's Ready)
75w90 - Motul Gear 300 or Silkolene Syn5 (Now Fuchs Titan)
I recommened either of the two listed - both have been used without issue.
Interval = 2 Years / 30,000miles depending on use/power levels
Hi all i drive an air plane with four tires aka a mk4 supra n/a because there was no tt available on island...hopefully by 2020 ill be the first...thanks to you guys ive learned so much abouts cars in general, and looking forward to a hell of lot more adventures/ upgrades
