Confetti seat repair
Tommyd16
So the seat bolster on my recaro is well and truly knakkered! So I bought some replacement foam and had a crack at it tonight imageimageimageimageimageimageimageimage
I have foam for the side support aswell but I haven’t got a clue how to get to it. Might just wait and take it to the trimmers because the material is well worn as well
Ive done this repair myself, and bought the parts from capital seating. You will find that if you have Supra specific confetti seats the shoulder bolsters on the new foams wont be big enough. But if yours are the type fitted to the st205 then you should be fine.
IIRC i had to pull the reliner handle and wheel off the side, then you unclip the fabric at the bottom of the back rest, then it pulls over. I think the harness holes are 2 sections (front and rear) which unclip, but it was some time ago. There may also be a metal ring at each end of tge bottom which need opening up.
