B3any Posted April 27, 2003 Share Posted April 27, 2003 Just had the above fitted Gents, i guessed the screw at the back adjusts pressure, what kinda noise dya get if you screw it in more and if you screw it out less??? Quote Link to comment Share on other sites More sharing options...
GavinL Posted April 27, 2003 Share Posted April 27, 2003 If you want to change the tone you buy a purple insert. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 27, 2003 Share Posted April 27, 2003 From my experience running stock boost levels, the tighter the screw the sharper the noise, you get a better sound. I think it needs to be losend the more boost you're running tho.. someone with actual knowlage can take over from me now.. Quote Link to comment Share on other sites More sharing options...
B3any Posted April 27, 2003 Author Share Posted April 27, 2003 Originally posted by GavinL If you want to change the tone you buy a purple insert. Its got a purple inside Gavin...... Quote Link to comment Share on other sites More sharing options...
GavinL Posted April 27, 2003 Share Posted April 27, 2003 Originally posted by B3any Its got a purple inside Gavin...... In that case you need the silver insert (like the one I will be getting rid of shortly) Quote Link to comment Share on other sites More sharing options...
B3any Posted April 27, 2003 Author Share Posted April 27, 2003 but what about the screw? Quote Link to comment Share on other sites More sharing options...
Alex Posted April 27, 2003 Share Posted April 27, 2003 The screw adjusts the blow off nature of the SQV, by tightening and loosening the spring. Just leave it alone. Unless you feel boost is leaking. Then tighten it just a 1/4 turn at a time. Quote Link to comment Share on other sites More sharing options...
B3any Posted April 28, 2003 Author Share Posted April 28, 2003 I think, i'm best leaving it alone arent i? Quote Link to comment Share on other sites More sharing options...
Terminator Posted April 28, 2003 Share Posted April 28, 2003 Yep, if it aint bust don't mess with it. Quote Link to comment Share on other sites More sharing options...
B3any Posted April 29, 2003 Author Share Posted April 29, 2003 Ok no messing........ Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 29, 2003 Share Posted April 29, 2003 I couldnt help but play with my nut Sounds better for it though, I screwed it a little tighter. Probably not too much different from how it came though. Quote Link to comment Share on other sites More sharing options...
Terminator Posted April 29, 2003 Share Posted April 29, 2003 How did the sound change? This should get interesting. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 29, 2003 Share Posted April 29, 2003 Dunno.. more of a sharper whistle. Quote Link to comment Share on other sites More sharing options...
B3any Posted April 29, 2003 Author Share Posted April 29, 2003 Hmmmm, would you say it was louder Bobbeh......? Quote Link to comment Share on other sites More sharing options...
Alex Posted April 29, 2003 Share Posted April 29, 2003 The spring is under more pressure to not open the valve. This changes the sound to more of a whistle than a whoosh...the more you wind it up the harder it is to open and the less it does open and therefore, less air escape's - thus bypassing the entire reason for having it. If you want to fiddle then only do so by a 1/4 turn at a time. But there really is no gain to be had. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 29, 2003 Share Posted April 29, 2003 Originally posted by B3any Hmmmm, would you say it was louder Bobbeh......? Yeah, it spat it out sharper whistle than the drawn out gush b4. This was pretty crude testing though, I'll probably have another play with it on the weekend. As Alex said though, I only ended up going back to the sort fo position it came as, maybe a little tighter. So probably wise to leave it how it comes. Quote Link to comment Share on other sites More sharing options...
B3any Posted April 29, 2003 Author Share Posted April 29, 2003 Ok its def being left now Quote Link to comment Share on other sites More sharing options...
