Cranking but not firing
Dave Carroll
Hi guys
Long time since Ive posted anything, mainly as i have had a very slow build to convert my TT6 to single turbo.
The build is done now and was at the point for mapping, but I have a new issue which has jammed the brakes on.
The car would start and idle, with a bit of throttle feathering, but it would start then idle rough. I contacted Romain from syvecs who connected remotely to confirm the ECT sensor was kaput. So I replaced the sensor and wiring, now the syvecs reads the correct temperature.
I expected to start it up again at worst with the same difficulty as before, but all I got were a couple misfires, a pop, and constant turning over. Now it wont even cough like it wants to fire up, just turns over.
I removed the connection to the ECT sensor to try again but no change.
Wondering if anyone has any obvious pointers I should check as I have checked a few things, all ok so far.
Romain will have a look further at things remotely soon, but would prefer to have it running again first!
Some build specs:
Standard 1993 block
264 in/out cams
Syvecs s6gp
Borg warner s369
Asnu 1000cc injectors and associated fuel system
New whifbitz coils and new spark plugs
Thanks for any ideas guys!
