R154 auto to manual conversion package
Mk4Gaz
As per the title, this is a complete package, including everything you need to convert your supra from automatic to r154 manual.
This is a mk3 box with extended shifter to fit the mk4 chassis perfectly. I sourced this box from James Hart (littlenum on here) about 15 months ago.
Everything pictured is included, namely:
R154 transmission
2jz Bell housing
Shifter extension
1jz lightweight flywheel and bolts
Cross member
Custom prop to fit a tt auto diff
Shifter including trd shift knob
Shifter boots
Slave cylinder
Master cylinder
Braided clutch hose
Clutch pedal
Marlin crawler speedo converter
Marlin crawler shifter bushes
Release fork
New output shaft seal
Spec 3+ clutch (1000 miles old)
Custom downpipe support bracket
Manual engine ecu
Manual trans ecu
Heat shield for master cylinders
I will also include a brand new output shaft seal.
The only things you will need to source, will be a manual shifter panel as I'm keeping that, a pilot bearing which costs around £10, and of course gear oil.
This box has been in my car for just over a year, and was using redline mt90, with a drop of molyslip in.
£3000
  • 2 weeks later...
Congrats with the sale m8!
Makes me think of the other day when my full manual swap was up for sale and people where crying all over the place because I asked for 4400GBP. Seems after all that my price was not that crazy (our swaps are pretty much the same except my box was marlin crawler rebuilded and upgraded jzz30 remote box and torsen LSD included, oem flywheel etc.).
Cheers m8
