brom86 Posted February 9, 2018 Share Posted February 9, 2018 Is there anyway to fix door card indents? Something had been leaning against it and there is a long indent where your arm would rest on the card. Wondering can it be pulled and return to normal? Quote Link to comment Share on other sites More sharing options...
peter richards Posted February 9, 2018 Share Posted February 9, 2018 ah the dreaded arm ripple mine is the same been like it for a long time , could fill it and then paint the panel , s m a r t repairers would do it Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted February 10, 2018 Share Posted February 10, 2018 Is there anyway to fix door card indents? Something had been leaning against it and there is a long indent where your arm would rest on the card. Wondering can it be pulled and return to normal? The actual armrests? Quote Link to comment Share on other sites More sharing options...
brom86 Posted February 10, 2018 Author Share Posted February 10, 2018 (edited) The actual armrests?No the cards Edited February 10, 2018 by brom86 (see edit history) Quote Link to comment Share on other sites More sharing options...
gaijin Posted February 10, 2018 Share Posted February 10, 2018 You could try warm-hot air from either a heat gun(be careful) or a hair dryer on a hottish setting The plastic covering has become stretched Heating it and carefully spreading it out might work Use an old credit card but also the palms of your hands with as much force as nessesary Work it and manipulate the covering in different directions It might work Good luck Quote Link to comment Share on other sites More sharing options...
brom86 Posted February 10, 2018 Author Share Posted February 10, 2018 You could try warm-hot air from either a heat gun(be careful) or a hair dryer on a hottish setting The plastic covering has become stretched Heating it and carefully spreading it out might work Use an old credit card but also the palms of your hands with as much force as nessesary Work it and manipulate the covering in different directions It might work Good luckCheers mate Quote Link to comment Share on other sites More sharing options...
