StainedBedSheet Posted February 5, 2018 Share Posted February 5, 2018 How is this done does anyone have a guide? http://jkwebdesign.net/lsocbb/viewto...er=asc&start=0 This site the pictures are down, I'm just wondering what size of washers are to be used and how thick, and where they extactly go. Thanks for the help gents. EDIT: If someone can give me the part numbers for seals ill need i'm upgrading my torque convertor. I have a front main seal,rear main seal,cam seals. I'm not sure what seals ill need for the transmission. I don't know if the oil pan has a gasket it or uses just sealent same with the valve body. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 5, 2018 Share Posted February 5, 2018 Take a look here - http://www.mkivsupra.net/vbb/group.php?groupid=57 You will also want to speak to this man - http://www.mkivsupra.net/vbb/member.php?25493-David-P Quote Link to comment Share on other sites More sharing options...
and1c Posted February 5, 2018 Share Posted February 5, 2018 Auto box sump just uses sealant, only a thin bead and make sure both surfaces are fastidiously clean! Quote Link to comment Share on other sites More sharing options...
StainedBedSheet Posted February 7, 2018 Author Share Posted February 7, 2018 Take a look here - http://www.mkivsupra.net/vbb/group.php?groupid=57 You will also want to speak to this man - http://www.mkivsupra.net/vbb/member.php?25493-David-PFor some reason links don't work. Quote Link to comment Share on other sites More sharing options...
StainedBedSheet Posted February 7, 2018 Author Share Posted February 7, 2018 Auto box sump just uses sealant, only a thin bead and make sure both surfaces are fastidiously clean!Thank you Quote Link to comment Share on other sites More sharing options...
zen Posted February 7, 2018 Share Posted February 7, 2018 For some reason links don't work. /QUOTE] Same here. Links don't work. Quote Link to comment Share on other sites More sharing options...
Scooter Posted February 7, 2018 Share Posted February 7, 2018 Are you guys paid up members that might be why they don't work? Quote Link to comment Share on other sites More sharing options...
Big Mark Posted February 7, 2018 Share Posted February 7, 2018 I had my old box shimmed by David. You need the box off the car and flipped over to make the whole job easier as gravity is not your friend on this job. The mechanism that needs removing, lots of bolts in 3 different sizes, so tip is to undo and lift off with bolts still in it, something you won't be able to do if working under the car. Bolts have to go back in correct locations. Also having box out makes sealing the sump back on easy as you can guarantee surfaces are completely clean of transmission fluid. Quote Link to comment Share on other sites More sharing options...
StainedBedSheet Posted March 17, 2018 Author Share Posted March 17, 2018 Are you guys paid up members that might be why they don't work?No I'm not a paid member Quote Link to comment Share on other sites More sharing options...
and1c Posted March 19, 2018 Share Posted March 19, 2018 Links work ok for me, I would suggest the small cost could be a wise investment as theres a lot of good info there. I think its £10 for a year>? Quote Link to comment Share on other sites More sharing options...
StainedBedSheet Posted March 26, 2018 Author Share Posted March 26, 2018 Links work ok for me, I would suggest the small cost could be a wise investment as theres a lot of good info there. I think its £10 for a year>?I paid for it but I couldn't find any thing to show me how to shim it. Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 26, 2018 Share Posted March 26, 2018 (edited) Anything good in here? http://www.mkivsupra.net/vbb/group.php?discussionid=143&do=discuss http://www.mkivsupra.net/vbb/group.php?discussionid=228&do=discuss Edited March 26, 2018 by Scooter (see edit history) Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 26, 2018 Share Posted March 26, 2018 There are no direct instructions on the forum, for the work necessary. David spent many, many hours working on these boxes, to find the 'sweet spot' with the shimming process, and I don't think he'd readily give up that information. But, if you contact him, and are willing to travel to him with your gearbox, I'm sure he'd be happy to do it for you Quote Link to comment Share on other sites More sharing options...
evinX Posted March 26, 2018 Share Posted March 26, 2018 There are no direct instructions on the forum, for the work necessary. David spent many, many hours working on these boxes, to find the 'sweet spot' with the shimming process, and I don't think he'd readily give up that information. But, if you contact him, and are willing to travel to him with your gearbox, I'm sure he'd be happy to do it for you /QUOTE] The guy is in Canada Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 27, 2018 Share Posted March 27, 2018 The guy is in Canada Ah, that could prove difficult then Quote Link to comment Share on other sites More sharing options...
