Cracked head
guy fawkes
Get a simple sniff test done by just about any decent garage which is cheap and easy to do.
If that comes up inconclusive get a compression test done obviously more involved so
a bit more money
I can recommend a local garage ive used for many years who are very good
and don't take the piss with the hourly rate, not far from Solihull
Many thanks, would appreciate that.
The 'sniff' test showed nothing but I'm told that may be because the crack is too small but it could open up when the engine temp goes over a certain point and I do find that the coolant loss fluctuates and after giving the engine a good burst there is gurgling coming from the rad head / expansion tank area !
