Jellybean Posted January 24, 2018 Share Posted January 24, 2018 Quick one , is there much involved or just basic tooling , unbolt the 4 bolts? Do I need spring clamps? Car is on Axle stands What are the torque settings for the lower and top mounts? Quote Link to comment Share on other sites More sharing options...
philw99 Posted January 24, 2018 Share Posted January 24, 2018 it's a job that's made loads easier with spring compressor i found, i'd used them to get the orginal's out on the front. Used this one: https://www.screwfix.com/p/hilka-pro-craft-coil-spring-compressor-kit-2-piece-set/45986 Getting the new front in was really easy, as they came apart then screwed back up on the tein suspension. Quote Link to comment Share on other sites More sharing options...
muckyman Posted January 24, 2018 Share Posted January 24, 2018 this is quite a good tutorial.... Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2018 Author Share Posted January 24, 2018 Thanks Guys I was just looking at that youtube vid I suppose what I am after is good technique , tricks of the trade experienced mechanics have to tackling this Do you need spring clamps , I would rather not have to buy additional tooling for a once off event Quote Link to comment Share on other sites More sharing options...
samdale Posted January 24, 2018 Share Posted January 24, 2018 Well there WAS a good, picture filled guide in the technical section. But photobucket are c****. http://www.mkivsupra.net/vbb/showthread.php?177475-How-To-Front-amp-Rear-Suspension-Change-Aftermarket-Coilovers-Adjustment Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2018 Author Share Posted January 24, 2018 Thanks missed that guide Quote Link to comment Share on other sites More sharing options...
samdale Posted January 24, 2018 Share Posted January 24, 2018 Double post Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted January 24, 2018 Share Posted January 24, 2018 I don't recall needing spring compressors for the CW Bilstein swap I did Carlo. Once the chassis is supported, the sway bars disconnected and the wishbones are free to droop to their lowest then I think it's just a question of bolt out & bolt in. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 24, 2018 Share Posted January 24, 2018 You don't need spring clamps. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2018 Author Share Posted January 24, 2018 Thanks Lads, Will give it a go , what could possible go wrong Quote Link to comment Share on other sites More sharing options...
bignum Posted January 24, 2018 Share Posted January 24, 2018 You'll need to remove the long bolt from the front upper wishbone, that's about the hardest part of the job, oh and setting the ride height, such fun! Also leave the rebound (setting on the bottom of the damper) alone, should be fine. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2018 Author Share Posted January 24, 2018 Thanks, I set them up as per KW default settings Will get Motorsport shop to set the ride height , corner balance them Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted January 25, 2018 Share Posted January 25, 2018 Thanks, I set them up as per KW default settings Will get Motorsport shop to set the ride height , corner balance them /QUOTE] Best get some adjustable drop links then too, if you are corner weighting.. Quote Link to comment Share on other sites More sharing options...
Marcus GTE Posted January 25, 2018 Share Posted January 25, 2018 I fitted these last year myself. Took me about 8h but had to cut the old drop link bolts and only had a hack saw to hand. I’m sure I found the guide on here very helpful. Also remember I had to modify the top mounts slightly to widen the bore so the top bolt would fit through. Good luck Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 25, 2018 Author Share Posted January 25, 2018 Best get some adjustable drop links then too, if you are corner weighting.. Any suggestions on manufacturer? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 25, 2018 Author Share Posted January 25, 2018 I fitted these last year myself. Took me about 8h but had to cut the old drop link bolts and only had a hack saw to hand. I’m sure I found the guide on here very helpful. Also remember I had to modify the top mounts slightly to widen the bore so the top bolt would fit through. Good luck Thanks , all my suspension is new so I am hoping a relatively easy time Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted January 25, 2018 Share Posted January 25, 2018 Thanks , all my suspension is new so I am hoping a relatively easy time /QUOTE] Just take your time especially on the drop link bolts as said as thats where time gets eaten for fun. However if its all relatively new you should be ok. Poss have a set of spring compressors to hand just incase as the front is very close but as also said before I think you can do it without. Best of luck, Let us know what you think of the KWs once done as we are trying to convince another member thats the way to go on his BMW. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 25, 2018 Author Share Posted January 25, 2018 Will do , I have Bilstein TRD on so hopefully they are alot more comfortable Quote Link to comment Share on other sites More sharing options...
Marcus GTE Posted January 26, 2018 Share Posted January 26, 2018 Will do , I have Bilstein TRD on so hopefully they are alot more comfortable They will be! Only thing I found with them is they can squeak while going over things like speed bumps etc. I contacted KW and they said it’s the oil traveling through the shock and normal. It seems to be during colder weather (where I guess the oil is thicker). When I get the car back on the rd after winter I’d like to try their softest setting for a while just to see what it’s like. FYI I don’t think you are meant to have them on the apsolute softest OR hardest settings; it’s meant to be one back from it. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 26, 2018 Author Share Posted January 26, 2018 Thanks Marcus! Quote Link to comment Share on other sites More sharing options...
bignum Posted January 26, 2018 Share Posted January 26, 2018 (edited) Nitron do some nice adjustable arb links, I may get some to match my setup. http://www.nitron.co.uk/catalogue_item.php?catID=13574&prodID=87765 Or white line. https://www.demon-tweeks.co.uk/Product.do?method=view&n=334&g=366116&p=366110&d=124&c=4&l=2&utm_source=Google&utm_medium=Base&utm_campaign=Anti-Roll%20Bars&gclid=Cj0KCQiAwKvTBRC2ARIsAL0Dgk2eo7WoT0hVO-9s26HNblhSikTIZ4_9s92vr8-DgWe9OtIm9l6m9kcaAjsqEALw_wcB&gclsrc=aw.ds Edited January 26, 2018 by bignum (see edit history) Quote Link to comment Share on other sites More sharing options...
Marcus GTE Posted January 27, 2018 Share Posted January 27, 2018 Thanks Marcus! You’ll love them. Is this crypto profits Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 27, 2018 Author Share Posted January 27, 2018 Nitron do some nice adjustable arb links, I may get some to match my setup. http://www.nitron.co.uk/catalogue_item.php?catID=13574&prodID=87765 Or white line. https://www.demon-tweeks.co.uk/Product.do?method=view&n=334&g=366116&p=366110&d=124&c=4&l=2&utm_source=Google&utm_medium=Base&utm_campaign=Anti-Roll%20Bars&gclid=Cj0KCQiAwKvTBRC2ARIsAL0Dgk2eo7WoT0hVO-9s26HNblhSikTIZ4_9s92vr8-DgWe9OtIm9l6m9kcaAjsqEALw_wcB&gclsrc=aw.ds Do you know what fits the Supra? Quote Link to comment Share on other sites More sharing options...
bignum Posted January 27, 2018 Share Posted January 27, 2018 (edited) Havn`t got a clue sorry mate, it will depend on how much you lower the car as to what angle it affects the arb, also defo don`t go too low with the front as you WILL have rubbing issues, the 685lbs springs arent really stiff enough for the supra.as i found out! Edited January 27, 2018 by bignum (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted January 27, 2018 Share Posted January 27, 2018 These have got jza80 in the fitment list for rears, https://www.ebay.co.uk/itm/KLC139-Whiteline-Front-Rear-Drop-Link-Assembly-for-Nissan-Skyline-R33-R34-GT-R/162236730572?epid=28011604684&hash=item25c6100ccc:g:BlcAAOSwzaJX~lLl Quote Link to comment Share on other sites More sharing options...
