ronttuk Posted January 24, 2018 Share Posted January 24, 2018 I need a alternator for a uk spec anyone got anything hanging about which works correctly? Link to comment Share on other sites More sharing options...
Dave Posted January 24, 2018 Share Posted January 24, 2018 If yours no longer works have you thought about a refurb did mine only cost 40 quid Link to comment Share on other sites More sharing options...
ronttuk Posted January 25, 2018 Author Share Posted January 25, 2018 Where from ?? Link to comment Share on other sites More sharing options...
Dave Posted January 25, 2018 Share Posted January 25, 2018 Where from ?? A local auto electrician I’m sure there will one near you Link to comment Share on other sites More sharing options...
pedrosixfour Posted January 25, 2018 Share Posted January 25, 2018 It depends on what the issue with your own alternator is. A set of brushes, a regulator or a bearing or two are easy fixes for any place doing alternator repairs. But something like a worn shaft or barly burnt windings make a repair uneconomic. Link to comment Share on other sites More sharing options...
Dave Posted January 27, 2018 Share Posted January 27, 2018 It depends on what the issue with your own alternator is. A set of brushes, a regulator or a bearing or two are easy fixes for any place doing alternator repairs. But something like a worn shaft or barly burnt windings make a repair uneconomic. Agreed but get it checked out before you lay mucho green on a new one Link to comment Share on other sites More sharing options...
pedrosixfour Posted January 27, 2018 Share Posted January 27, 2018 Oh for sure. But we get a lot of rotational electrics (alternator and starters) repaired in our line of business (forklifts) and we see a lot of the replacement components used failing long before (as in within 12 months) a decent used or new replacement unit might. It seems to be a common issue. I did have a new replacement alternator for the 1JZ fail within a couple of hours of fitting, but it was replaced with no questions, as a new unit is covered under warranty, whereas a repaired alternator is a bit of a grey area. They can always claim it was some other part that failed this time round. Sometimes a spurious new replacement doesn't cost much more than a service on a twenty year old unit. Link to comment Share on other sites More sharing options...
