HarleyFDMD Posted January 22, 2018 Share Posted January 22, 2018 Looking for a stock gte intake with throttle body and sensors Link to comment Share on other sites More sharing options...
Day881 Posted January 22, 2018 Share Posted January 22, 2018 Looking for a stock gte intake with throttle body and sensors /QUOTE]I got this if any good no sensors £60 Link to comment Share on other sites More sharing options...
HarleyFDMD Posted January 22, 2018 Author Share Posted January 22, 2018 I got this if any good no sensors £60 https://uploads.tapatalk-cdn.com/20180122/3aa920a67efb1cfc5b6438bb63c0826b.jpg /QUOTE]Hmm ok. Looks great but i think i might struggle finding the sensors on their own. I will keep it in mind though.. tbh im not entirely sure what sensors i need - its to go on an aristo vvti engine because the aristo intake isnt compatible with a supra apparently - in particular the throttle body Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 22, 2018 Share Posted January 22, 2018 Aristo and Supra VVT-I intakes and runners are the same. The TB on the VVT-i engine is different to the non VVT-i GTE engine. Link to comment Share on other sites More sharing options...
Day881 Posted January 22, 2018 Share Posted January 22, 2018 Hmm ok. Looks great but i think i might struggle finding the sensors on their own. I will keep it in mind though.. tbh im not entirely sure what sensors i need - its to go on an aristo vvti engine because the aristo intake isnt compatible with a supra apparently - in particular the throttle body /QUOTE]Ok mate no problem just let me know ah right yh i wouldn't know not to sure Link to comment Share on other sites More sharing options...
HarleyFDMD Posted January 22, 2018 Author Share Posted January 22, 2018 Aristo and Supra VVT-I intakes and runners are the same. The TB on the VVT-i engine is different to the non VVT-i GTE engine.Ah ok thanks Frank, its the throttle body that is my biggest concern really. The aristo throttle body uses an electric throttle control/butterfly whereas the supra throttle body uses a fly by wire Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 22, 2018 Share Posted January 22, 2018 Ah ok thanks Frank, its the throttle body that is my biggest concern really. The aristo throttle body uses an electric throttle control/butterfly whereas the supra throttle body uses a fly by wire /QUOTE] Nope, they are both the same. The VVT-i TB uses a clutch based system with gearing from a DC motor which is a lot slower also the response is not linear due to a heavy spring which is used to return the motor back to closed if not powered. You have a few options I can think of. Use the OEM VVT-i parts. Runners, intake and TB. But should the VVT-i TB go tits up it’s an expensive part to replace and rarely comes up for sale secondhand. Also see above re compromise. Get an adaptor made up to fit the VVT-i intake and fit a Bosch TB from a Porsche or similar. You will need a true DBW pedal if you decide to go this route. Get shot of the VVT-i intake, runners and TB and go with the non-VVT-i intake, runners and TB with a cable. Link to comment Share on other sites More sharing options...
HarleyFDMD Posted January 22, 2018 Author Share Posted January 22, 2018 Nope, they are both the same. The VVT-i TB uses a clutch based system with gearing from a DC motor which is a lot slower also the response is not linear due to a heavy spring which is used to return the motor back to closed if not powered. You have a few options I can think of. Use the OEM VVT-i parts. Runners, intake and TB. But should the VVT-i TB go tits up it’s an expensive part to replace and rarely comes up for sale secondhand. Also see above re compromise. Get an adaptor made up to fit the VVT-i intake and fit a Bosch TB from a Porsche or similar. You will need a true DBW pedal if you decide to go this route. Get shot of the VVT-i intake, runners and TB and go with the non-VVT-i intake, runners and TB with a cable.Thank you Frank, you're clearly more clued up on this than me! I'll be using the non vvti intake/throttle body. Thanks you for your help. Just need to find a complete intake now! Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 22, 2018 Share Posted January 22, 2018 Thank you Frank, you're clearly more clued up on this than me! I'll be using the non vvti intake/throttle body. Thanks you for your help. Just need to find a complete intake now! /QUOTE] No problem I can’t take all the credit, this was something myself and Jason aka j_jza80 looked into a while ago. Link to comment Share on other sites More sharing options...
HarleyFDMD Posted January 22, 2018 Author Share Posted January 22, 2018 No problem I can’t take all the credit, this was something myself and Jason aka j_jza80 looked into a while ago.Well thank you none the less. I know what to look for now. Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 23, 2018 Share Posted January 23, 2018 Or you can convert you current VVTI throttle body back to a cable driven TB using the following: http://www.driftmotion.com/2JZ-GTE-VVTi-ETCSi-Drive-By-Wire-Delete-p/dm3403.htm Works a treat. Just used it on an aristo engine in a supra running link ecu. Link to comment Share on other sites More sharing options...
HarleyFDMD Posted January 24, 2018 Author Share Posted January 24, 2018 Or you can convert you current VVTI throttle body back to a cable driven TB using the following: http://www.driftmotion.com/2JZ-GTE-VVTi-ETCSi-Drive-By-Wire-Delete-p/dm3403.htm Works a treat. Just used it on an aristo engine in a supra running link ecu.Im going to have a look at this i think. Thanks Mike Link to comment Share on other sites More sharing options...
jimjam92 Posted January 25, 2018 Share Posted January 25, 2018 I got this if any good no sensors £60 https://uploads.tapatalk-cdn.com/20180122/3aa920a67efb1cfc5b6438bb63c0826b.jpg /QUOTE] I'll take this if still available? Just to confirm it is pre-VVTi? Link to comment Share on other sites More sharing options...
Day881 Posted January 25, 2018 Share Posted January 25, 2018 I'll take this if still available? Just to confirm it is pre-VVTi?pm you Link to comment Share on other sites More sharing options...
