Supra mk4 2jz manual prop shaft
WIDESUPRA
Ive just checked what I've got.
I bought a na auto, and na manual prop back in the summer. I have one rear half which I believe are the same for both, and two front halves - one I believe is auto, the other manual.
The carrier bearing can simply be swapped over if the one its fitted to is incorrect.
I could send you all the pieces for £100 posted. The only thing missing, are two of the bolts that hold the two halves together
If you can confirm what the correct total length for a na5 prop is, I can double check for you
Not sure if this helps?
