guys help a girl out....stock fuel pressure at idle...urgent!!!!!
tephanie
Info from USA Supraforums
Toyota GTE Service Specs...
Fuel Pressure at Idle w/vacuum hose disconnected is 33-40psi (2.3 - 2.8 kgf/cm)
Fuel Pressure at Idle w/vacuum hose connected is 24-31psi (1.7 - 2.2 kgf/cm)
Correct fuel pressure at idle doesn't necessarily confirm a correct fuel pressure at boost. Fuel pressure should always be 36 psi. above the intake manifold boost pressure at all times.
example...10psi boost =46psi FP, 15psi boost=51psi FP, 20psi boost = 56psi FP
Toyota GE Service Specs...
Fuel Pressure at Idle w/vacuum hose disconnected is 38-44psi (2.7 - 3.1 kgf/cm)
Fuel Pressure at Idle w/vacuum hose connected is 28-34psi (2.0 - 2.4 kgf/cm)
