Big Mark Posted January 19, 2018 Share Posted January 19, 2018 Anyone else with the carbon scuttle got gaps where the rubber sealing strip meets the glass in one or two places? Not sure if it's normal, or mine is warped. Either way how the hell do I get the sealing strip to seal, I don't want water getting down there. [video=youtube;kp6tZ-HdSVo]https://www.youtube.com/watch?v=kp6tZ-HdSVo Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 19, 2018 Share Posted January 19, 2018 Water will get down there, even with an oem trim piece. The rubber isn't sealed to the glass, so will never be water tight. It's to stop leaves and shit getting down there, and probably to stop it reverberating against the screen at speed. That warp is probably just a byproduct of a composite part. Solid plastic is a lot more resilient to warping through external factors (sun, cold, etc) Quote Link to comment Share on other sites More sharing options...
muckyman Posted January 19, 2018 Share Posted January 19, 2018 run a thin bead of black silicon along it, and then trim to a neat edge with a stanley blade once its cured. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted January 19, 2018 Author Share Posted January 19, 2018 run a thin bead of black silicon along it, and then trim to a neat edge with a stanley blade once its cured. So basically bond the edge of the scuttle to the windscreen? Will be interesting if I even need a new windscreen........... Quote Link to comment Share on other sites More sharing options...
Big Mark Posted January 19, 2018 Author Share Posted January 19, 2018 Water will get down there, even with an oem trim piece. The rubber isn't sealed to the glass, so will never be water tight. It's to stop leaves and shit getting down there, and probably to stop it reverberating against the screen at speed. That warp is probably just a byproduct of a composite part. Solid plastic is a lot more resilient to warping through external factors (sun, cold, etc) /QUOTE] I think it's more my OCD wanting it to fit evenly all the way across more than anything else. After all the factory plastic one has big vent holes in it so isn't exactly waterproof. Quote Link to comment Share on other sites More sharing options...
luke supra Posted January 19, 2018 Share Posted January 19, 2018 I'd get some 3m refix double sided tape (what badges are stuck on with its really thin) and put under it mate. That will keep it down and is easily removable should you need too. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted January 19, 2018 Author Share Posted January 19, 2018 I'd get some 3m refix double sided tape (what badges are stuck on with its really thin) and put under it mate. That will keep it down and is easily removable should you need too. Great plan. I've got some of that stuff already, I'll dig it out and stick the bugger down! Quote Link to comment Share on other sites More sharing options...
muckyman Posted January 19, 2018 Share Posted January 19, 2018 So basically bond the edge of the scuttle to the windscreen? Will be interesting if I even need a new windscreen........... no, no - don't use something to 'bond' it. Black silicon will remain rubbery, like the sealant around the top of a bath and the tiles. If you ever needed to change the windscreen the silicon should just peel away. The silicon will help keep the majority of running water from getting in there but remain flexible and removable. Stay away from bonding materials like tiger seal etc. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 19, 2018 Share Posted January 19, 2018 (edited) Cant you cut tiger seal with a scalpel if it needed to come off ? As long as your careful and just run a thin bead on the seal i don't see a problem to be honest Edited January 19, 2018 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
luke supra Posted January 19, 2018 Share Posted January 19, 2018 Great plan. I've got some of that stuff already, I'll dig it out and stick the bugger down! Quote Link to comment Share on other sites More sharing options...
kitch79 Posted January 19, 2018 Share Posted January 19, 2018 I carefully removed my seal off the OEM and then used evo stick to glue it to the new carbon one. Bit fiddly, but worked great. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 19, 2018 Share Posted January 19, 2018 I carefully removed my seal off the OEM and then used evo stick to glue it to the new carbon one. Bit fiddly, but worked great. Getting it too sit tight onto the screen is the problem Quote Link to comment Share on other sites More sharing options...
Big Mark Posted January 19, 2018 Author Share Posted January 19, 2018 I carefully removed my seal off the OEM and then used evo stick to glue it to the new carbon one. Bit fiddly, but worked great. I've got the OEM seal on it. But that's no use when warpage is creating gaps. Quote Link to comment Share on other sites More sharing options...
-K1 Posted January 19, 2018 Share Posted January 19, 2018 i got the same gap on mine.. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted January 19, 2018 Share Posted January 19, 2018 I've got the OEM seal on it. But that's no use when warpage is creating gaps. Uh Jesus. Just watched the video, didn’t realise it was so far off!! Mine was tight before the seal went on Quote Link to comment Share on other sites More sharing options...
samdale Posted January 19, 2018 Share Posted January 19, 2018 I've never worked with carbon fibre so not sure on this but can you bend it slightly by applying weight and then heat? Then it stays in the new shape once cooled? Quote Link to comment Share on other sites More sharing options...
Big Mark Posted January 19, 2018 Author Share Posted January 19, 2018 I was wondering if something like that would remove the gap. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 19, 2018 Share Posted January 19, 2018 I'd have thought once its cured then it stays out of shape, same as fibreglass I'd stick it down or get it replaced if possible Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted January 19, 2018 Share Posted January 19, 2018 That gap is massive, is that not a faulty item? Quote Link to comment Share on other sites More sharing options...
evinX Posted January 19, 2018 Share Posted January 19, 2018 For the money they cost and compared to how the oem sits flush. Id return it. That would drive me nuts personally mark. And there have been pictures of good fitting ones. Id ask for a replacement. If your happy to. Get some thin 10mm double sided tape and thatll pull it in shape. But end of the day it should sit flush. Quote Link to comment Share on other sites More sharing options...
bayside_supra Posted January 20, 2018 Share Posted January 20, 2018 I don’t think these ever fit perfectly, I was close to getting one but this is why I left it Quote Link to comment Share on other sites More sharing options...
