SSI -- Nice new parts out and coming
Jellybean
Some nice new parts coming out , street kit looks promising
Hopefully they will do an LED conversion rather than having to send my dials to the Stu in the states
hybrid GT3582R turbochargers. Uprated billet wheel, uprated dual ceramic dual BB CHRA, T51R compressor modification, tial .82 AR exhaust housing.
From what I hear is it connected to a Cast manifold, probably something similar to the FSR ported unit
SSI 2JZ Extreme I-beam connecting rods
They also have a Supra PNP ECU with all the bells and Whistles ,
they have a nice 60mm guage (air vent ODsize) , you can toggle the screens , fuel pressure , water temp , boost ...
https://scontent-sea1-1.cdninstagram.com/vp/18f5496c6fa3ba5dd13323752a08105f/5A5FB418/t51.2885-15/s480x480/e15/19534681_522588714799162_51808227691593728_n.jpg?ig_cache_key=MTU0OTY2MDYwMzQ0MDgyNDUxNA%3D%3D.2
https://scontent-sea1-1.cdninstagram.com/vp/1eef7192272a383188e9fb94d44018fb/5A5FC298/t51.2885-15/s480x480/e15/19533822_808160476014191_9103248235446665216_n.jpg?ig_cache_key=MTU0OTY0MDg3MzY4NjUwMjgzMg%3D%3D.2
The EF46 is a full-fledged sequential injection system ECU.
Injection :-
4x individual injector drivers control for opening time at 1/1000 milliseconds accurately. fully sequential 4 cylinder, 8 cylinder semi sequential
Injector timing at 0.1 degree adjustable per speed and load
Amount of injection per injector adjustable (Injector Trim)
Various fuel injection strategies adjustable (MAP, MAF, AlphaN, ITB)
Siamese inlet semi- and full-scale injection
Adjustable deceleration stop before injection
Closed loop mixer with Air Fuel ratio target value table
Injector staging
Flex Fuel Sensor Connectable (E85 or BioEthanol)
Injection field changeover
Igintion:
6 x individual ignition output for "smart coils" with built-in end stages (V12 in wasted spark mode)
Ignition timing with a precision of 0.1 degree accurate
Detonated offset adjustable for Odd-four engines (Ducati, Harley Davidson, Maserati, PRV engine)
Ignition field changeover
Coil charging time adjustable and correction for battery voltage and acceleration
Ignition timing correction at inlet air temperature
Idle and load-dependent stationary timing
Drives Stock system or COP's such as Audi r8
Other
Many different speed sensor (VR, HALL, Opto) and triggerwheel configurations possible
Adjustable speed limiter (Spark retard, Spark cut, Fuel cut)
Stationary speed control via PWM motor or Stepper motor
Launch control, Flat shift, Sequential shift, switch release for automatic bins
Boost pressure control
Tachometer output
Control of electric fans
Barometric correction
fuel pump controller
0-5V Analogue input for Exhaust Gas Temperature module
0-5V Analog input for Knock Sensor module
programmable outputs
Communication
USB
Bluetooth
RS232
CANbus
Edited by Jellybean (see edit history)
  • 2 weeks later...
