Mgrene Posted January 13, 2018 Share Posted January 13, 2018 I’m about to install gauges which of course shall turn on when you turn on the ignition. But when I look at the wire diagram, there is apparently two wires. One for ignition 1 and one for igntion 2. Which one should i chose and why is there two? Quote Link to comment Share on other sites More sharing options...
jagman Posted January 13, 2018 Share Posted January 13, 2018 ign 1, the ign 2 is kept on during cranking the engine and provides the ignition and fuel and ECU - This prioritises these during cranking as the voltage drops from the battery to ensure engine starts the ign 1 is removed during cranking and returns after engine start ( switch returns to ign1) the ign 1 are not required to start the engine a lesser priority during low volts situations Quote Link to comment Share on other sites More sharing options...
Mgrene Posted January 13, 2018 Author Share Posted January 13, 2018 So which one do you suggest I use for gauges etc? Quote Link to comment Share on other sites More sharing options...
Mgrene Posted January 13, 2018 Author Share Posted January 13, 2018 Now I think twice, it was actually a stupid question. I should use IG1 since IG2 only will be on for s short period. Edit. Also see now that you suggest IG1 Thanks mate. Quote Link to comment Share on other sites More sharing options...
jagman Posted January 13, 2018 Share Posted January 13, 2018 Ign 1 This is for all other circuits not needed to start the engine Quote Link to comment Share on other sites More sharing options...
Mgrene Posted January 13, 2018 Author Share Posted January 13, 2018 Final question. How about ACC ? Can that also be used? Quote Link to comment Share on other sites More sharing options...
jagman Posted January 13, 2018 Share Posted January 13, 2018 ACC is for accessories- things you want to have switched on without having the ignition on , saving the battery being drained over longer periods , so it powers the radio allowing you to listen when parked up , or have a smoke (cigar lighter - high load but only for a short time) So no , unless you are into looking at your gauges while nothing else is running - lol Quote Link to comment Share on other sites More sharing options...
Mgrene Posted January 13, 2018 Author Share Posted January 13, 2018 Jagman you are a star. Thumbs up. Quote Link to comment Share on other sites More sharing options...
jagman Posted January 14, 2018 Share Posted January 14, 2018 Just for completeness and an overview : Some circuits are directly fed bypassing the ignition altogether- this allows these to operate without needing your keys , usually horn , so you can beep your mate without fumbling for keys , the headlight flash for similar reasons and hazards , these are very short term loads , sometimes the heater fans work , to allow passenger cooling or heating if the driver has left the car with the keys . This also has the effect of reducing the current that passes through the ignition switch - the more current passing through an ignition contact , the more likely it will fail , another reason for multiple switch contacts. Adding any electrical items requires some thought as to where you draw the power from , usually this never happens and some of the most random wiring installs are the result - a total nightmare for the next owner , especially when it goes wrong ......17 different circuits all fed from the cigar lighter - lol Quote Link to comment Share on other sites More sharing options...
Mgrene Posted January 14, 2018 Author Share Posted January 14, 2018 Will the ACC also be shut down while IG2 is cranking the engine? Quote Link to comment Share on other sites More sharing options...
Mgrene Posted January 14, 2018 Author Share Posted January 14, 2018 And will there be no power going through IG2 & ST1 as soon as the key returns to IG1 ? Quote Link to comment Share on other sites More sharing options...
jagman Posted January 14, 2018 Share Posted January 14, 2018 The diagram represents the switch sequence - first click is ACC - this is powered , the second click powers ign 1 as well , at the same time ign2 is powered , the next click is sprung loaded to start - at the same time ign 1 and ACC is opened and ign 2 remains closed After start you release the switch and all 3 are now powered - until you turn back to off or ACC . This is why ignition switches have some length to them , the contacts are along a shaft so contacts can be operated at the same time by some cam or key way on the barrel shaft all turned by the key . And why you can get some weird problems when an ignition switch contacts go bad or worse intermittent , key barrels worn etc . All normal car stereos are around 45-50 watts for example - this is not because manufacturers can make more powerful amps , but car wiring is rated to a max current that gives 45-50 watts - bigger amps could bugger the wiring and ignition switch ACC contacts . Hence mahoosive aftermarket amplifiers run direct off a battery lead . Aftermarket things fitted , we all have them , need some thought , how much load and current , and things like start current on rad fans or motors etc - you can't just hook them up to any nearby powered wire just because it's handy - lol I've seen so many cars with high quality mechanicals and cosmetic installs with shockingly bad wiring installs - I always try and imagine their Xmas tree light installs at home - 7 extension reels all loaded with plugs !!!! Quote Link to comment Share on other sites More sharing options...
