Dzowani Posted January 7, 2018 Share Posted January 7, 2018 Need help removing pillar handle? Does it slide off or is there a screw behind the rubber handle? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted January 7, 2018 Share Posted January 7, 2018 Need help removing pillar handle? Does it slide off or is there a screw behind the rubber handle? There are a couple of bolts holding the handle and trim on Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted January 8, 2018 Share Posted January 8, 2018 You can google this on ebay. You will see how it looks at the rear from the seller photos. It has to be sort of pryed off with a flat screw driver. Behind that is the mounting square plates that are held by a screw each holding the pillar trim in place with its two grommets. Quote Link to comment Share on other sites More sharing options...
Dzowani Posted January 8, 2018 Author Share Posted January 8, 2018 So the handle needs to slide of?? Or should i bend the robber handle to get to the bolts? Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted January 8, 2018 Share Posted January 8, 2018 It can pull toward the centre like how you would pinch a hose I assume. It cant slide of the ends or something. You could try and move it from the edge to see where you could use a flat taped up screw driver to pry it off. Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted January 8, 2018 Share Posted January 8, 2018 Try this link mate. https://www.ebay.com/itm/Toyota-Supra-JZA80-Passenger-Side-Assist-Grip-Handle-set-NEW-Genuine-OEM-Parts-/172264043502 Quote Link to comment Share on other sites More sharing options...
evinX Posted January 8, 2018 Share Posted January 8, 2018 Theres an arrow at the top or bottom one side comes off first, flatten the handle then pull that side off... Quote Link to comment Share on other sites More sharing options...
