Ls400 diff with a01b lsd. Will it work? - confirmed
goldenvtr
Seen information that the ls400 3.2 open diff is a straight swap for my small case a01b. But I cant find any info if it's possible to make it a torsen using my a01b internals. Essentially making a 3.2 torsen. (For my bmw swapped trans)
Anyone got any experiance in this? I don't have the space in my garage at the moment to drop my diff off and experiment.
Edited by goldenvtr
title edit (see edit history)
I have a B04D diff from an IS300 which is a direct fit if your interested!
info seems limited on that diff code, whats the ratio on it and is it a torsen?
edit just found this:
Crown Wheel Size A A (8'' - 200mm), B (8.7'' - 220mm)
Differential Ratio 01 01 (4.083:1), 02 (3.769:1), 03 (3.267:1), 04 (3.538:1)-UK, 05 (4.272:1)-USA, 07 (3.133)-USA
Differential Type A A (Standard open differential), B (Torsen LSD), D (Torsen LSD)
so it sholld be a big case, 3.538 ratio,torsen
its not the 3.2 im looking for but if price is right id give it a try....pm'd
Edited by goldenvtr (see edit history)
Clear your inbox mate I can’t pm you back!!
  • 1 month later...
so i though id update this it works.i bough a ls400 diff 3.2 from a 2000vvt model,
swapped the ring gear, driveshaft 3bolt flange and rear case housing, and bolted it all back together. exactly what i needed and cost me bearly anything :)
ratios suit the getrag 420g perfectly for what i wanted .
few photos before i just cracked on it with
  • 10 months later...
  • 4 weeks later...
This is exactly what I wanted to read when i came on tne forum today :). I have the 420G also and find the ratios way too small. Going single turbo soon and want it to actually build boost. Thanks for the great info ��
Same! Car is the garage now having the 420G installed, but when its back I need to change the diff at some point as the 4.1 ratio isnt the best when going turboooooo, 3.7 or 3.2 would be ideal
