Project. 96 jspec tt6
Neumann
hello fellow supra owners! let me make a short introduction, my name is johan, 28 years old from sweden. i bought my supra back in 2013, i have never had any intentions of making a project thread so there is no pics of everything.
heres the car when i picked it up
as you can see it has a veilside kit with a trial rear :p
anyway, the engine was stock when i got it, exept a catback exhaust. i drove around and enjoyed the car all summer. then i decided to fit a fmic beacuse the stock one was falling appart
as you can see i am allso fitting an oil cooler there and a filter relocation kit
next thing to change was the diff bushings
i allso decided to change the clutch, so i bought a exedy twin disc, just in case i might go single some day..
here it is getting the new clutch installed
the clutch was very easy to drive, very pleased with it..
i allso changed the bumper to a stock one:
then i fitted some ridox replica skirts
then i thought i would put a do luck bumper on..
i started to want and up the power, so i began fantasise about a single turbo.. so i bought some shit
Turbo sxe s369
manifold
wastegate precision 46mm
injectors bosch ev14 1300cc and a 450 pump. Nuke fuel rail and preassure regulator
EMU ecu
again so sorry for the lack of pictures :(
off to tune
as you can see somewhere along the way i put a euro/uk scoop on
rmm wing on there now allso as you see... the care made about 590whp, had to stop there due to fuel problems, i used to stock wiring for the pump and it was to small..
i fitted some new jr wheels and enjoyed my new beast of a car as i thougt it was :rolleyes:
i could only upload 20 pics in this first post so i will have a beer and continue below..
wheel alignment
Daily for life :innocent:
this was the last pic i took of the car before....
...the hydraulic tensioner decided to quit its job in the middle of a fiftg gear full boost pull. i spun a rod bearing :(
so i did the only thing i could do.. build a new engine :D:D
te recepie:
Brian crower HD rods
Cp pistons 10.0:1
HD wristpins
Real street billet maincaps
PHR oil pump
Brian crower 272 camshafts
Brian crower valve springs
Billet tensioner bracket
fluiddampr crank pulley
arp bolts to everything
allso bought a new crank
OEM headgasket
nice and clean
cams torqued down
bought a intake manifold and powdrer coated it black. i have previously powdercoated the valve covers
all done!
i will take a small brake again... more to come
Engine dropped in
found a complete 220mm diff with propshaft dirt cheap so had to buy! as my car us a facelift i have the 200mm from factory
allso changed the steering wheel to a newer one, previosly i had the 4 spoke wheel
i built myself a downpipe with wg pipe. 3.5"
time to dyno!
so i drove pretty much all summer flawlessly.. now i decided to pull the engine and paint the engine bay and some other things
pulled the engine
and i became tired of all the fibre glass shit on the car so i bought a new oem bumper and found some used oem facelift skirts, and a oem rear bumper :)
i decided to clean up the engine bay, so i deleted the abs and put the fusebox in the trunk
bought some new brake lines for a clean look
heres the wiring harness all layed out, everything i dont need was removed, all the wires were extended to allow them to be tucked away
i allso bought a new ecu and gonna build a flying lead to it.
and with this i will be going drive by wire, so i bought this bosch 82mm throttle
i will use a pedal from a lexus sc400 wich i allready bought and bolted to the car.
i orderd some new japaneese wheels allso :innocent::innocent:
they are 18x9.5" & 18x11"
then i picked up some tires, toyo r888 265/35 for the front and 315/30 in the rear
mounted and balanced
then i test fitted my new wheels along with the skirts, bumper etc i got a while back.. this is present day and from now on i will document everything better
Here is a full specification of the car if anyone's interested.
BLOCK
Brian crower HD Rods with arp 2000
realstreet performance billet main caps
CP pistons 86.5mm 10.0:1 compressor ratio.
CP heavy duty wrist pins.
ACL race rod & Main bearings
Powerhouse racing oil pump
Powerhouse racing billet timing bracket
fluiddampr crank piller
toyota 36.2 vvti trigger wheel
HEAD
Brian crower Valve springs
work adjustable cam pulleys
INTAKE
greddy intake manifold
bosch 82mm electric throttle Body
Tial Q 50mm blow off Valve
EXHAUST
Lennart exhaust manifold t4 divided
borg Warner s300sx-e 9180. 69mm
precision 46mm Wastegate
homemade 3.5" downpipe to a 3" exhaust
FUEL
Bosch ev14 1300cc Injectors
Nuke fuelrail
Nuke fuel pressure regulator
wallbro gst450 intake pump x2
speeding -8an ptfe fred -6an return
E85 fuel
DRIVETRAIN
exedy hyper multi twin plate clutch
Getrag v160
220mm torsen diff
COOLING
LMR intercooler 550x300x114
setrab 19row oil coolt
mocal oil thermostat
driftworks supercool radiator
volvo two speed radiator fan
BRAKES
DBA discs
carbotech XP10 pads
WHEELS
work meister s1 3p 18x9.5 18x11
toyo r888 265/35r18. 315/30r18
VARIOUS
ECU master EMU Black with flexfuel sensor. Oil pressure sensor, fuel pressure sensor. 2x EGT sensor for failfafe
nippondenso 160amp alternator
Thats just att the top of my head, will probably add more and post everything in the first post.
first off i started removing all the old body sealant beacuse that is smeared all over the place from factory, got no pictures of that im affraid.. then i put on new sealant in all the places needed..
heres the stuff i used
very easy to apply..
here i have applied the new sealant
then i sanded down the bay and started to mask it
some more masking..
then i primed the places that needed to be primed.
and here i painted the lowest sides of the bay and the left side of the firewall
tomorrow i will paint the rest :)
i allso wanted to show my new coolant overflow tank that i bought on chasebays on black friday sale, very nice piece and will look awesome in the bay
Nice work, will you be chasing more power later?
Thanks man :) No i'm not gonna up the power anything, atleast not for now. the turbo is pretty much maxed out at the moment anyway. I have dyno time 28th of mars, im gonna settle for around 850whp this time beacuse i felt 970 was abit much, i drove around all Summer with "low boost" 1.7bar = 775whp, that was alittle to little though :p we'll see :)
Nothing major happend today, i went to the local hydraulic shop and had a new high pressure hose made for the PAS pump to rack.
New hose
Then i went ahead and put the enigne and radiator in so i can start to make some new hoses for a couple of oil coolers, a filter relocation and meassure in the wiring to the flying lead.
The engine is alittle dusty from standing in a corner for a while :p
Where did you guys relocate your filters to? I want the easiest acces possible. I have a couple of ideas in mind.
  • 7 months later...
