need an LSD 3.2ish? can part ex my a01b :)
goldenvtr
If you want a 3.2 diff then you will need to use BO3B or AO3B diff which go for like £1k to 2k. Plus you need the meatier driveshafts to fit as well.
3.7 AO2B (~£450) is what I normally recommend to run on 420g, unless you plan on going 200 mph +
Haven't tested it yet, but I've heard that IS220d diff could be made to work without a ton of work and they are even lower ratio than the big case supra diffs
cool thanks for the input ill have a look into the is diffs, im not afraid of some custom work :),
i wont be tracking the supra, maybe a drag day for interest but no top speed melarkie
am i right in thinking the a01b i currently have is a 3.9? im literally driving round using 4th and 5th lol without even lugging the engine, feel like 2nd gear only just breaches 40mph .
with that in mind, id be happy to try a a02b out... any takers for a swap ?
am i right in thinking the a01b i currently have is a 3.9? Im literally driving round using 4th and 5th lol without even lugging the engine, feel like 2nd gear only just breaches 40mph .
With that in mind, id be happy to try a a02b out... Any takers for a swap ?
a01b = 4.083:1
