any BT engineers on here
peter richards
I'm not on Openreach engineer (if it's a Wi-Fi problem) however I am a BT Power Engineer. Common misconception that it's BT that sort the housing side of the telecommunications. Happy to help if I can though?
If it is a Wi-Fi issue I can also send off the issue to a private section of Openreach that sort "family and friends" issues that are having issues with resolvement.
Sam
ok thank you I'm on BT business , supposed to be guaranteed speed , no fall off , BB been slow and my stream is useless atm so checked my speed throughout the day and it been really low , contacted BT cs and they recon up to my house is 65 meg and faultless , so how can it be so bad inside ive only got this 1 pc and an amazon tv box
router is a business hub 5 3 months old
also BT wants 245+vat for someone to come out lol
wired , when we first went with bt , we had plugs fitted to the socket by the hub and one by the pc , not syre what they are called , so a cable from this plug into the router and again from the plug to the pc
pc is on the floor above the router
just checked the speed and its 15.86 and 6.62 which is low compared with the guaranteed 30+ they said id have and no drop off
Have you been using something such as speedtest.net to check it? What sort of download and upload have you been seeing? Annabella has kindly asked my 2nd question!
What sort of building are you in? It's possible to have other equipment signals interfere with the wifi, and it's also possible that if you have other routers in the same area that routers on the same signal channel can "fight for dominance"
Unfortunately this is definitely an Openreach problem, and out of my personal skill range (I only know certain things through fixing issues with my internet myself)
If you can't get it sorted by the end of this thread though I'm more than happy for you to send me a complete breakdown of the issue and I'll forward it onto the family and friends service for you, they've helped people I know in the past.
My first suggestion would be to change your filter;
Second suggestion would be to open the socket you're connected to and put it into the internal test socket directly and run more speed tests.
This is the first 2 steps an Openreach engineer would probably take from experience of them being around sorting my internet in the past
ok only the one router in the house, ive had up over 30 meg but for some reason its droped off and it shouldn't , one of bts selling points to get me to change to the business package
cs said its a problem inside , as up to the front door its 65 meg and no issues , ive not changed anything inside so don't know what to try , if I call them tomorrow they will say the same I think
The problem will be the homeplugs you are using or rather the electrical circuit the data is going through. You need to borrow a long ethernet cable that will reach your pc to eliminate the homeplugs as a test. Are the homeplugs plugged into a wall socket at both ends or an extension? They really don't like surge protected ones. They ideally need to be directly into the wall sockets. Ive seen massive electronic interference from fridges on same ring main degenerating the signal quality. A few things to try for you!
I run a hard wired and a DLAN network for the home and business (same site but two entirely separate buildings). I get pretty much the same speed at the filter, at the router, at the Ethernet and at the DLAN (wireless or wired). There is no more than 2Mb difference on a 20Mb filter delivery. So if you are seeing a large drop then I recon you have issues with your filter or you have an overloaded network with several bandwidth hungry applications or your adapters are poorly located. If you access the router (BT Hub) menu you will be able to see the number of devices connected and there should be a menu option to see how much data each connection is pulling in (a historical total since last reset). You may not be able to easily identify the item as you may be presented with a MAC address list but it will give you an idea what is happening across the network and if you have something hogging the network and bandwidth.
With the DLAN part of my network I find that the location of the plugs has a serious impact on speeds obtained, I have sockets in the building with virtually no connectivity and others with excellent connectivity. I used the Devolo plugs and their monitoring cockpit software. With the software you can see the data speed available from each socket location you try. Also, you do need to plug the DLAN adapter plugs directly into the socket, never into an extension or multiple outlet plug. Because the socket choice can have such a major impact on data speeds available I only use the wireless adapters. Then if its a good location and my PC happens to be nearby, of kodi box, or TV or whatever then I can connect it by a cable. If its not nearby then I used the wifi to connect. Adapter location is very sensitive so if you don't have monitoring software to see the connected data speed that the location yields then you will be working very much in the dark.
Where is the 65mb figure coming from?
Let’s start with understanding your line, visit https://www.dslchecker.bt.com enter your phone number and screenshot the results, it should look something like the attached.
You will see from this that the max my line will support is 59mb the handback figure 35mb is a kind of indication/expected rate you would expect to receive, I’m actually getting 46mb.
Next logon to your router http://192.168.1.254 and click on “connection” you will see 2 figures upstream and downstream sync, these are the speeds that your router is connected at...
So if your router is reporting 65mb downstream and XX upstream then your setup locally is rubbish...
As advised homeplugs should only be plugged into the socket, not into extensions etc, i use homeplugs but still get the 46mb throughout my house, if there is a management software for your homeplugs then install this so you can monitor the rate that they are managing to connect at, you might find that the environment that they are operating in is causing the issue as anything plugged into your electrics can effect this.
Report back with your findings and we can advise further.
Cheers
hi rob its 65 to the house front door , spoke to an advisor yesterday he checked again and came back with the same figure and no faults in the area , I checked the speed constantly yesterday and it was low 20s all day on DL UL was around 16. he agreed that something isn't right so is sending me another hub , then go from there , because if I have an engineer call and its something in the house apart from the hub what else could it be ill get charged 245+vat, which this time of the year I really don't want
If you're using homeplugs ( what use the electrical cabling to make a network connection ) the issue is probably there.
You need to plug in directly to the modem with a cable to check speeds correctly.
Ideally you should log into the modems administration pages and check the "sync speed" this is the actual speed the modem has with the telephone exchange and you should see speeds near that value.
God knows I am no expert, but do as Ric says, forget the internet over the mains crap, isolate them by plugging the PC itself direct into the router / modem. If speed is good it'll be the internet over the mains Home Plug stuff that is the bottle neck, that is the bane of radio hams lives as they give a load of spurious RF noise, and general dissatisfaction to their users. A proper hard wired network is more work, but probably worth the effort
