Defi dash
kaahari
I was really interested about Defi dsdf until the specs came and the screen is very small :( Did this instead for a test how it would suit to Supra.
Screen is standard android 7" tablet, connected to Defi advance unit via smart adapter. I'm using only advance unit sensors (non obd), since my car in pre vvti... (obd is laggy on this).
I used old lhd cluster panel for "base" and top panel is made from polycarbonate... kind of prototype, would like to make this better if it turns to be good.
On the software side, only running automation prog to run software when car ignition is on. I used this a few weeks before winter to check that on software side everything works... and then started to implement warning lights, case and harness. Warning lights etc are standard toyota/lexus and "base" for those is from old jdm cluster so bulbs are replaceable. Harness uses plugs from old jdm cluster so unit is plug&play to cars oem lhd dash harness.
Just liked to share my progress on this :)
Prototype
Testing...
Cluster test on car
Also modded Defi software to more modern look with LFA & Lexus inspired background & needle.
In live, screen and graphics are very sharp, very hard to take good pics on this due screen brightness.
Edited by kaahari (see edit history)
  • 3 weeks later...
