Dash panel air vents info
SupraTRD_MK4
Good day all
I will be needing one after I have acquired other parts. I have seen a listing for it on Ebay mentioning both are the same which I believe is nonsense. I tried fitting the one I have on the left and with a slight fuss, it would not go into the left panel. So I tried it on the right side panel above the key hole and mirror adjuster and it went in. I have verified the part numbers and they differ. I am slightly confused as if I ever pull the gun on the item from this seller, I may be sold the incorrect one which they believe is the same for both sides. Please assist? It is a RHD car and cluster panel surround.
