Sigorney14 Posted December 12, 2017 Share Posted December 12, 2017 Hi I'm wondering if anyone maybe able to help I've got a vvti which I've just singled it's running on a adaptronic modular m 2000 ecu and 1000 cc denso injectors my local mapping shop have come across a issue on low boost 7pi the car runs fine however once boost goes 0.8 bar or above it develops a miss fire they have tried new coil packs and igniter and also new plugs but still has a miss fire does anyone on here have any other ideas like could it be injectors I'm at a loss and feeling a little fed up any input from anyone in the no would be really appreciated many thanks Wes" Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted December 12, 2017 Share Posted December 12, 2017 (edited) What condition are the coil pack clips in? Did they use OEM coil packs? Also what plugs were used? See here - http://www.mkivsupra.net/vbb/showthread.php?41927-FAQ-Spark-plugs Edited December 12, 2017 by Frank Bullitt Link Added. (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 12, 2017 Share Posted December 12, 2017 As above, are they the correct grade plugs, correctly gapped? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 12, 2017 Share Posted December 12, 2017 Check for any trigger/rpm sync errors on the ECU. Check you aren't hitting some sort of ignition cut due to a safety limit. Given that it's giving you issues with more boost then I would hazard a guess it has something to do with your combo of ignition coils/spark plug gaps etc. As for injectors, try and see what duty cycle they are running at with more boost, check you aren't running too lean/rich etc. Quote Link to comment Share on other sites More sharing options...
