Loads of interior trim!
Supragal
Anyone breaking a supe with a clean interior?
I need the following (pretty much the entire back of the car)
I've got prices from Toyota but could really do without paying main dealer prices for stuff I should already have :mad:
6x nuts for fuel pump coverplate
Springy bit for the fusebox lid
ecu coverplate
Part number Description Quantity
67911B Plate, front door scuff, outside RH 1
67912A Plate, front door scuff, outside LH 1
62381B Weatherstrip, roof ride rail, RH 1
62382B Weatherstrip, roof ride rail, LH 1
62211 Garnish, front pillar, RH 1
62212 Garnish, front pillar, LH 1
62217G Clip, front pillar garnish 2
62533B Bracket, quarter trim, RH 1
62534B Bracket, quarter trim, LH 1
62311B Weatherstrip, front door opening trim, RH 1
62312B Weatherstrip, front door opening trim, LH 1
67924A Clamp, door scuff plate, no2 2
90168-40055 Std part (bolt) 6
74610A Grip sub-assy, assist 1
74681 Retainer, assist grip, upper 1
74682 Retainer, assist grip, lwr 1
74631B Hook, coat 1
63388B Stopper, roof 1
90159-40049 Std part (bolt) 1
75710 Moulding assy, front door belt, RH 1
75720 Moulding assy, front door belt, LH 1
90189-04118 Std part (hole) 24
90168-40002 Std part (bolt) 24
67751 Board, back door trim 1
67881A Weatherstrip, back door 1
64901B Tonneau cover retractor 2
64795A Trim, back window opening 1
64716D Cover, deck trim, rear 1
90168-40055 Std part (screw) 4
64716F Plug, hole (for deck trim rear cover) 4
64730C Board, deck trim side, RH 1
93567-54514 Std part (screw) 14
64714B Plug, hole (for deck trim side cover) 14
64740B Board, deck trim side, LH 1
64770D Cover assy, spare wheel 1
62616B Cover, quarter wheel house, inner LH 1
64714E Clip (for deck trim side cover) 2
62615B Cover, quarter wheel house, inner RH 1
64716E Clip (for deck trim rear cover) 2
64910J Cover assy, tonneau 1
68171B Weatherstrip, front door glass, inner RH 1
68172A Weatherstrip, front door glass, inner LH 1
67862 Weatherstrip, front door, LH 1
67861 Weatherstrip, front door, RH 1
62111B Std part (popper) 2
Rosie, I think you will need to post photos of parts, or diagram from the EPC showing them indicated, so we can identify the parts, as the EPC descriptions and part numbers won't mean a thing to most members.
Ok... but if I had the parts to photograph I wouldn't need to buy them eh? :D :p
Rosie
Think I will have just about all of this stuff you are after - price will be at 50% of Toyota retail to give you an idea
Car is being broken over next couple of weeks - so let me know if you are interested
Rgds
Me
thats brilliant paul toyota just gave me a list of all teh prices so that'll make it easy to work out :thumbs:
Are you taking all those bits out or do you want me to come get them?
Rosie
Rgds
Me
I need one or two parts paul.. Its not on rosies list :eyebrows:
You might want to speak to jezzybabes off here, i think he has about 3 sups that are/have been stripped and should be able to help you out with some bits...
I was there a couple of weeks ago, there isn't really that much on the cars themselves unless he has it stashed away inside somewhere.
Great
These i will get all boxed up for you - and then will be available for colection etc
Speak at SEM on Tuesday?
rgds
paul
