wrighty338 Posted December 3, 2017 Share Posted December 3, 2017 Hi On friday my daily car was broken into in the early hours and they got away with my wallet, keys to my lockup and 1 of my supra keys the lockup keys can be changed no problem but obviously someone out there (with or without knowing it) has a key for my supra along with the alarm fob. This is obviously not good so the locks and barrel on the car need to be swapped ASAP - are these available to buy still from anywhere? Quote Link to comment Share on other sites More sharing options...
rider Posted December 3, 2017 Share Posted December 3, 2017 Its going to be difficult for them to track down where your lockup is unless the thief knows you so I personally wouldn't go to the expense of changing all locks on the car and just change the lock on the lockup. If its a real concern you could always add a steering clamp to the car? If you are set on changing locks over Keron should be a good starting point for a breaker set with a set of associated keys at a fraction of the price of new. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 3, 2017 Share Posted December 3, 2017 Remove the EFI relays from the engine fusebox, so then the car won't be going anywhere unless the thief also happens to be an auto electrician Keron would be your best bet for new key barrel set. Quote Link to comment Share on other sites More sharing options...
keron Posted December 3, 2017 Share Posted December 3, 2017 Hi,yes if you need a lockset I’m sure I still have full sets avail. Call me tomorrow if you need one Thanks Quote Link to comment Share on other sites More sharing options...
wrighty338 Posted December 3, 2017 Author Share Posted December 3, 2017 Cheers Quote Link to comment Share on other sites More sharing options...
