WayneW Posted December 3, 2017 Share Posted December 3, 2017 Hello I ve to change the oil pump of a friend's tt6 supra. His front crankshaft seal is leaking so this is the opportunity to change the (theoreticaly) 23 years old oil pump! Our aim is to get the Supra to à ~600ps single turbo conversion in the futur. Do we need to put smth other than à new oem one or ? Ps : waterpump will also be changed for a stock one. Also ok ? Cheers ! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 3, 2017 Share Posted December 3, 2017 If the front main seal is leaking its a sure sign the oil pump is worn, so changing it is the best idea, its also a good idea to open out the size of the drain hole behind the seal in the pump case, offhand i cant remember the size but there will be an extensive write up on the problem by me, if you search for it. Quote Link to comment Share on other sites More sharing options...
WayneW Posted December 4, 2017 Author Share Posted December 4, 2017 I don't find your old write up... nomatter I'll put a new oem one this will do the job Thanks. Quote Link to comment Share on other sites More sharing options...
