Large case UK Spec Diff - Spares or Repair
TRD-1
Hi Guys,
Ive had this diff for a few years now in my garage, its from a UK spec Supra I think I don't know to much about what type or spec it is, it has the diff cooler, it was fitted to a Aristo but due to lack of oil has seized, the drive shaft ports still turn, but the prop shaft side doesn't. The casing seems ok and not damaged as does the cooler.
As far as I know the oil cooler had been blocked off with caps, but one of the caps had split and this is where the oil leaked out from causing the failure. Might be a possible repair with new internals.
Im after £60 for it collected from Gravesend Kent.
Thanks
[ATTACH=CONFIG]223914[/ATTACH]
[ATTACH=CONFIG]223915[/ATTACH]
[ATTACH=CONFIG]223916[/ATTACH]
[ATTACH=CONFIG]223917[/ATTACH]
[ATTACH=CONFIG]223918[/ATTACH]
[ATTACH=CONFIG]223919[/ATTACH]
