B04B diff how much?
fastcar
I've also never heard of the '04' coded diff before, it's not in any of the VIN frame documents I have. It might be a late spec VIN/parts change that was made so if that's the case I'd love to see a pic of the VIN plate. It might help the VIN decoder I've been updating the last 10+ years :)
As far as I'm aware there are A/B (Small/Large case) then 01/02/03 (Ratio) then A/B (Open/Torsen) on the diff code
B02B or B03B should easily get £1k, but 03's can go for much more.
Homer if you know anyone with a UK Spec Auto, they should be running a B04D from memory.
UK spec Auto is indeed B04D, just checked a car here
Thanks Lee, that's a mod I need to make to the VIN plate calculator. The '04' and 'D' sections aren't listed in the Euro or US spec sheets so I've always been 2nd guessing the UK ones. Odd as I've thought them same/similar to Euro.
That`s what I said. :)
Indeed you did and thank you for responding to the question, some of us learned something new :thumbs:
This also means the diff on my RSP Supra is a B04D, good to know!
Homer: This B04D diff is most likely from the UK Spec A/T Supra. Same differential is in (most, I remember that some of the Austria and Switzerland A/T cars do have the B03D (3.267:1) diff) Euro Spec A/T Supra´s and also Middle East supra N/A`s.
