matt hands Posted November 25, 2017 Share Posted November 25, 2017 hey. my crankshaft pulley broke and the bolt wont come out. tryed a gun and wont move, removed the starter motor to get to the flywheel but dont have the proper tool to lock it and cant find it anywhere. is there another way of remove the bolt or where can i buy a flywheel locking tool for a supra. i have removed the rad and fan to make easy acces to the bolt. i have a manual mk4 2jz ge if that helps Link to comment Share on other sites More sharing options...
evinX Posted November 25, 2017 Share Posted November 25, 2017 I got this to make my life easier next time http://www.garagewhifbitz.co.uk/toyota-2jz-1jz-crank-pulley-lockup-tool.html Link to comment Share on other sites More sharing options...
matt hands Posted November 25, 2017 Author Share Posted November 25, 2017 thanks Link to comment Share on other sites More sharing options...
Scooter Posted November 25, 2017 Share Posted November 25, 2017 put it in gear and have someone sit in/on the brake then with a breaker bar and a scaffold pole over the top give it the beans....careful of the bonnet. Basically some can be very very tight Link to comment Share on other sites More sharing options...
mellonman Posted November 25, 2017 Share Posted November 25, 2017 use the engine mate had mine off easy, so you put the breaker bar on the floor , pull the efi fuse so the car don't start , crank the engine job done Link to comment Share on other sites More sharing options...
