ben_harmer32 Posted November 23, 2017 Share Posted November 23, 2017 (edited) Going to be fitting a TT HG to my NA for it's turbo swap. Just wandering if there are any differences in HG's or i can buy any that states it's for TT? Currently looking at this one: https://www.ebay.co.uk/itm/253217626991 Also what other bits should i replace whilst i'm in there? Cheers! Edited November 23, 2017 by ben_harmer32 (see edit history) Quote Link to comment Share on other sites More sharing options...
ben_harmer32 Posted December 7, 2017 Author Share Posted December 7, 2017 Anyone help with this? According to parts website TT head gasket part number is 11115-46051 One on that listing is 11115-46052 Quote Link to comment Share on other sites More sharing options...
ben_harmer32 Posted December 14, 2017 Author Share Posted December 14, 2017 ?? Quote Link to comment Share on other sites More sharing options...
evinX Posted December 14, 2017 Share Posted December 14, 2017 Isnt it usually NA head gaskets they fit to TTs becuase the NAs are high compression. So why remove the better gasket for a inferior one? Quote Link to comment Share on other sites More sharing options...
ben_harmer32 Posted December 14, 2017 Author Share Posted December 14, 2017 (edited) Isnt it usually NA head gaskets they fit to TTs becuase the NAs are high compression. So why remove the better gasket for a inferior one? possibly, but they change to a TT HG for the NA as it's thicker and lowers compression allowing more boost I believe Edited December 14, 2017 by ben_harmer32 (see edit history) Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted December 14, 2017 Share Posted December 14, 2017 (edited) THE tt head gasket is used on the na to lower the compression so you can up the boost. I also run a tt gasket on my na-t so now run 1.2 bar Edited December 14, 2017 by sidewaysdan (see edit history) Quote Link to comment Share on other sites More sharing options...
evinX Posted December 14, 2017 Share Posted December 14, 2017 Ah ok got it Quote Link to comment Share on other sites More sharing options...
Style Posted December 15, 2017 Share Posted December 15, 2017 Only guess about the part numbers being different is that it's non-vvti and vvti. If you can find out which one is which then go for the non-vvti one you'll be fine Quote Link to comment Share on other sites More sharing options...
steve spedd Posted December 15, 2017 Share Posted December 15, 2017 OR you can fit the TT pistons and install an NA gasket. That's what I have. Quote Link to comment Share on other sites More sharing options...
steve spedd Posted December 15, 2017 Share Posted December 15, 2017 I do have a TT head gasket in the Garage should you go that route. Quote Link to comment Share on other sites More sharing options...
Dave_Batch Posted December 15, 2017 Share Posted December 15, 2017 Think its standard item, 1.2 or1.3mm that's what i used Quote Link to comment Share on other sites More sharing options...
goldenvtr Posted February 3, 2018 Share Posted February 3, 2018 i used a tomei 1.8mm headgasket, and then had my head skimmed (0.2mm) just to ensure it was 100% smooth my compression ratio is now 8.4 give or take 0.1 only other thing i changed was arp head studs, also cleaned deep cleaned the head/valves and piston tops etc Quote Link to comment Share on other sites More sharing options...
