Big UK Spec Single Turbo, Fully Built Engine, 6spd Manual 800fwhp - Full History 3 Ow
Sheefa
Evening
I have decided to put my beloved 1995 UK Spec Big Single Turbo Manual up for sale. It was displayed at the NEC Classic Car Show in 2016 and has covered less than 500 miles in a year. Reason for sale is I'm bored, have a second child on the way and want to use the capital to make money via other means. If the car doesn't sell for the asking price I will keep it as simple as that.
I have owned the car for over a 2 years having purchased it off a previous member whom had owned it for 16 years. He bought it from a Toyota Dealership complete with all paperwork which I have retained. It has had 3 owners from new. It is a UK spec car (not a grey import) and these are becoming extremely rare to find, especially in this stunning condition. It has without a doubt been garaged for 18 years of its life so surface rust is minimal and there are NO structural defects etc. It is estimated that there are fewer than 150 UK Specification Supra's that we know of on the road today. This car is finished in the original 199 Alpine Silver.
The car has covered just over 93,000 miles and is in fantastic condition throughout. It has never been involved in an accident or stolen and has had a clean HPI history since it's manufacture. The panels are perfectly aligned and there are no signs of any repair work. Please message me for reg details to undertake HPI check.
The interior is flawless with perfect dash panels, leather seats, polished bezels and immaculate carpet and headlining. It is of a showroom standard. Equally the exterior is in lovely condition and is OEM apart from the CCW wheels (cost over £3k) and bespoke front and facelift rear lights. I would personally rate the paintwork at 9/10. I recently had the front drivers' wing sprayed by PL Carbodies in Warwick at a cost of £385 due to some moderate stone chipping and the paintwork matching is spot on. There are a couple of small stone chips which have been touched up but to a very good standard and for a 22 year old vehicle the paintwork is glossy and near pristine. There is a small blemish on the roof which can probably be machine polished out but I am happy to have rectified before any closing sale.
The car has been meticulously modified and maintained over the last few years by Littlenum (PerformanceHart) and Supra Racing Developments (SRD) and over the last 24 months I have personally spent in excess of £ 18,000 upgrading the older single turbo setup and accompanying modifications to the latest and best modern technology including a full new turbo system, twin pumps and 1100cc injector fueling, full Syvecs engine management, OS Giken racing differential, New fuel system, remapping etc. The bill in July 2016 alone for parts and labour from SRD totalled over £12k. Nothing but the best parts have been used here and all of the major components are brand new and have covered less than 3,000 miles.
Underneath the chassis is clean, the control arms and bushes are in great condition and there are no corroded areas. The car has been kept in a garage for the last 18 years of her life and is very much a warm weather vehicle only. This is an extremely clean and well cared for UK Specification Supra.
This car is putting down some serious power and at high boost runs 690rwhp on pump fuel and over 750rwhp on a 50% ethanol mix meaning well over 800 engine power. The car has devastating power but equally is extremely reliable and also refined when you want it to be having switchable mapping modes via the Toucan controlled by Syvecs ECU and the comfort of new fully adjustable HKS HyperMax IV Suspension. Most of the time I run the car on medium boost setting so around 600rwhp which is more than enough.
As well as all of the receipts for work undertaken during my ownership I have a folder full of receipts from over the last 10 years including the CCW Wheel invoice, new coil packs, gearbox seals, front and rear crank seals etc etc.
Full specification of the vehicle is as follows but please do drop me a message or pick up the phone to talk through the extensive changes, all of which have been completed to the highest of standard with no expense spared.
Forged Engine
Fully Built and balanced engine & Head with less than 16k miles and compression tested by Lee P at SRD when I bought her in October 2015 (189 across all cylinders with cylinder 5 at 183 so all well within tolerance). Then in September 2017 Greg @ ProTuner did a compression test and all was near perfect again. Pic enclosed. This engine is spot on and extremely strong.
HKS (Carrillo) rods
Oversize CP Piston and Ring Set (3.1 litres)
New crank (sub 7,000 miles)
SRD Stage 2 Cams 269
Ferrea Ti retainers
Polished Q45 throttle body
SRD Greddy style intake manifold
Polished cam covers
Engine Components
New Fluidampr crank pulley sub 1k miles
SRD/Powerhouse Racing Polished Alloy pulleys
Gates Racing Kevlar Cam belt
New Toyota Timing Pulley
New Toyota Belt Idler
PHR Idler Pulley
Modifed oil pump.
Turbo System
Precision Turbo Billet CEA Gen 2 6466 900HP Turbocharger
Powerhouse Racing Stage 3 HKS ceramic coated manifold
SRD turbo oil line kit
DEI T4 Titanium Turbo Blanket
DEI Titanium Heat wrapped PHR 4” ceramic coated downpipe/midpipe
Dual HKS BOV’s
Fuel System
ASNU 1100cc Fuel injectors
Custom Teflon Fuel lines
Twin Walbro 485 pumps (one brand new sub 300 miles)
Powerhouse Racing Fuel Rail
Aeromotive Fuel Pressure Regulator
Exhaust
Veilside 4" Pearldrop Titanium 3.5" Exhaust (with optional bung) modified to be 3.5" all the way
4" Downpipe and 4" Midpipe
Double Decat Pipes
Cooling
GReddy 4row Front Mounted Intercooler
10 row power steering cooler
16 row Oil Cooler
New Rear diff cooler
Custom Airbox
PWR Polished Aluminium Radiator with twin electric fans (ECU Controlled)
Electronics and control
Syvecs S6 ECU (Tuned by SRD)
Syvecs Toucan Controller
Syvecs Innovate Motorsports Wideband (ECU Connected)
Syvecs Oil Temp sensor (ECU monitored)
New Fuel flex Sensor & Ethanol
Syvecs Fuel pressure sensor (ECU monitored)
New Coil packs
Syvecs Enhanced Knock sensors (ECU monitored)
Syvecs Oil pressure probe (ECU monitored)
Boost control valve (ECU controlled and monitored)
Battery relocation to boot with full wiring
Laser Line Cat 1 Thatcham approved Car alarm
Transmission
Stock Getrag V160 6 speed Manual
New OS Gilken LSD Large Case Differential and new seals
RPS Streetmax Clutch and OEM Dual Mass Flywheel
AP Engineering Shifter Bushing Kit
Modified clutch slave cylinder & braided line
Suspension
HKS HyperMax IV Suspension (Awesome ride and comfort, fully adjustable)
TRD Anti-roll bars
Full Geometry setup completed at fitment by SRD in November 2015
Wheels & Braking
18” CCW Classic Wheels with chrome lip and Matt centre finish complete with custom caps
New Toyo Proxe T1-R tyres
Upgraded steering rack bushes
UK Spec brakes (newly rebuilt with seals, boots and Pistons) with full braided stainless hoses, new stock discs and Porterfield Fast Road Pads all round
New OEM brake lines.
Interior
TRD 10K tech Speedo
Toyota Celica steering wheel and ABS connector
MVP Aluminium pedals
MVP Aluminium dial surround
Heater Control Polished Bezels
Sparco Milano Prestige leather seats
Brand New 6spd Manual Gearknob
Bride seat rails
Leather gear and handbrake covers
Pioneer Double DIN DVD, Ipod and MP3 head unit
Kenwood lightweight speakers.
Bodywork
Stock OEM bodywork
Whifbitz lower lip with 2” hose pickups
Bespoke LED Halo Ring Facelift Headlights
LED Facelift Front Indicators
Clear Side Repeaters
Facelift Rear Lights
Other Parts
Carbon Fibre Engine Cover
Carbon Engine Bay Boxes
SRD Aluminium Engine Under tray
APR Carbon Cooling Plate
Polished Fuse Box and Brake Res Covers
Polished Strut Covers
Aluminium Rad overflow tank
Chromed Top radiator hard pipe
Whifbitz carbon fibre bonnet dampers
Power
Currently 753rwhp at 2 bar on 50% ethanol mix (670rwhp on pump fuel). Various adjustable boost modes via the Toucan.
Bad Bits/Niggles:
Genuinely none I know of at all except a small paint blemish on roof, hardly noticeable and can probably be machine polished out.
This is an unbelievable car and is in fantastic conditional mechanically and cosmetically for the new owner to enjoy it. The value of Supra's continues to appreciate and this is a very strong purchase being a well built UK Spec car. You could quite easily return this to OEM standard I am sure given there are plenty of parts out there should this be your desired route.
Please note I will not divulge the vehicles location until I have spoken to you and verified your details. Email or call me number in sig.
I will not accept ANY offers below the advertised price.
I will not allow you to drive the car when coming to view (I will drive).
Price advertised as above is £33,000 or £34,500 supplied with a brand new RPS Twin Carbon Billet Clutch (retail is £3k) not supplied only not fitted.
Please call me or message for further information.
Regards
Greg
  • Replies 63
Just for the record, anybody that offers any less will be told, politely perhaps, to go (insert expletives) and review recent sale threads for big singles. This is a UK car with FULL history, big modern single turbo setup, crash/theft free, no expense spared. I assure you that you shall be troubled finding any better example. Greg.
Thanks all, appreciate the nice comments.
A serious part of the sale is the fact I refuse to track the car for obvious reasons and despite the limited free time I'll have post December I will get myself a little track day car sub £5k for occasional fun. I already crap myself in this car and driving it hard around a track self conscious and anxious just isn't me.
