Mounting Knock sensor
Samurai 20V
Hi all.
I am installing a Bosch wideband sensor on my BPU TT6 for furture use.
Having an issue with finding a spot on the block to mount it.
With the motor in the car and all the stuff on the intake side, can't seem to find a spot.
Any advice on where to mount and how to mount it?
Was thinking of removing the fuel pulsation damper and mounting it on that point.
Is the noise of the fuel with the damper removed audible from inside the car?
Thanks guys.
  • 3 weeks later...
Just to complete this for anyone searching.
I removed the fuel pulsation damper, freed up holes 7 and 12 on the intake side. Fitted the whiftbitz bypass.
Swapped the bracket for the water line to the oil cooler from 2 to 7. added another L bracket make it work.
Then mounted sensor to 2.
Pic below.
