Gauging Interest - Full Brand New OEM Suspension
Sheefa
*UPDATE BACK UP FOR SALE*
I have a full set of OEM front and rear suspension parts, control arms, strut rods, bolts, camber bolts, washers, drop-links etc for the front and rear of the Supra. The only parts not ordered were the Front Upper Control arms as these don’t tend to wear as fast and mine are in great shape. I can provide full part numbers.
All parts were ordered from TCB parts back in February 2017 and June 2017 and have been sat in bubble wrap in a sealed box in the loft. All parts are absolutely immaculate having been inspected. Full parts list is as follows:
Rear Suspension
8* 90201 14020 washer, std part – Genuine Toyota £1.38 each + VAT (3 Days)
48730-14040 Rear Lower Arm – RH
48740-14070 Rear Lower Arm – LH
2* 48710P Nut, No2 rear lower control arm
2* 48710N Nut, No1 rear lower control arm
48194H Cam, rear suspension camber adjust No2 RH
48198R Cam, rear suspension camber adjust No2 LH
2* 48198H Cam, camber adjust, No2
48710-14110 Rear Arm Assembly RH
48710-14110 Rear Arm Assembly LH
2* 90179 12027 std part, nut
2* 48710N Nut, No1 rear lower control arm (Same Part as the lower arm Nut)
2* 48198H Cam, camber adjust, No2 - (Same Part as the lower arm Cam)
48194G Cam, rear suspension camber adjust, No1 RH
48198G Cam, rear suspension camber adjust, No1 LH
48780A Rod assy, rear
2* 48780C Nut for strut rod
2* 48780B Bolt for strut rod
48725-14070 Bush, rear axle carrier 48725F RH
48725-14070 Bush, rear axle carrier 48725G LH
48770A Arm assy, Upper control, rear RH
48790 Arm assy, Upper control, rear LH
4* 48770D Nut for rear upper control arm
2* 90201 14031 std part, washer
2* 48770F Ring, E for rear upper control arm
2* 48757 Attachment, rear suspension arm
2* 48770H Bolt, rear upper control arm RH
2* 48790B Bolt, rear upper control arm LH
Front Suspension
48610G Nut for front upper suspension arm RH
48630C Nut for front upper suspension arm LH
4*90209 14007 std part, washer
48610F Bolt for front upper suspension arm RH
48630B Bolt for front upper suspension arm LH
2* 90468 16016 std part, castle nut binder
1 x 48657A Stopper
48068-14080 Front Lower Arm sub assy
48069-14080 Front Lower Arm sub assy
2* 48068G Nut for front suspension lower arm RH
2* 48069C Nut for front suspension lower arm LH
4* 90201 16017 std part, washer
2* 48194D Cam, front suspension camber adjust No2 RH
2* 48198D Cam, front suspension camber adjust No2 LH
1* 48657A Stopper, front lower arm bush
2* 48194C Cam, front suspension camber adjust No1 RH
2* 48198C Cam, front suspension camber adjust No1 LH
2* 95622 11200 std part, washer
2* 90170 12036 std part, nut
All rear I paid £2k and front a little under £1k but with some additional bits on top like the stock roll bar mounts (£30) and drop-links (£50). Prices have also gone up since as supply is limited. I’ll let everything go for £3.2k collected - no other offers accepted. All bits here and ready to go.
Collection only from Bromsgrove, B60.
These are becoming harder to source, many have been discontinued, there are many stories of these being damaged in overseas transit - mine are in perfect order and ready for delivery.
Please message me if genuinely interested or contact me on 07521931366.
Thanks
Greg
£3k sounds about right. Your prices look discounted or old compared to prices I paid in September to TCB. You went in double bulk on these purchases so maybe did get a little extra discount than if you hadn't pooled your purchase. It might be worth getting a up to date price from TCB and you'll probably find your no profit price is actually a discounted sale which may make it more appealing to potential buyers.
Thanks all. There's quite a few people that have expressed interest so I will calculate the exact figure, post confirmed individual part numbers up and go from there.
Prices may of gone up, but I'm not here to profit from the sale only cover my expense so that'll be the price advertised.
That's not a bad price to be fair.
I paid £3273 for all the bits, then had to get bolts and a bush kit when I started mine so that was more money added on top.
So far the rear is nearly all fitted to my stripped and powder coated subframe, but the fronts I haven't touched yet.
I will probably be letting them go soon enough now I am stripping the supra.
  • 5 months later...
Rear Suspension
Front Suspension
1 x 48657A Stopper
Thanks
Greg
  • 1 month later...
  • 3 weeks later...
