R154 gearbox full conversion
berg
R154 gearbox conversion
I pieced this together last year, very rare gearbox now and very rarely pop up for sale, this box is the later type from a JZX100 Chaser
so has the remote shifter cradle, electronic speedo etc so no modifications are needed, this will bolt straight on unlike the old mk3 supra boxes
Selling as a full manual conversion including the following
R154 gearbox (complete with shift cradle, gear knob, crossmember & mount, all sensors)
1JZ flywheel
SPEC Stage 3+ clutch kit (only done 2k miles)
Slave cylinder & clutch fork
HEL braided clutch line
Clutch master cylinder and reservoir
Clutch and brake pedals
Custom propshaft
Manual dash panel
Manual RPM gauge piece (fits over your original rpm needle)
All nuts bolts etc
The shifter cradle has solid bushings installed which emits slight noise into the cabin, but stock w58 bushings fit the cradle and can be bought still
This is a complete manual conversion ready to bolt straight on and is proven to hold single power perfectly,
Doesnt have a manual tunnel skin but these are still available from toyota
The rear end of the propshaft uses an n/a supra flange, designed to fit the diff flange on the A01 diffs, it does however still fit the A02 range
just takes a bit of fettling to get the rubber donut onto the prop, but i can leave this on the prop if using one as i currently use an A02B diff myself
A02B diff not included but can be available seperately if needed as its very well matched to this gearbox
Price is £3500 SOLD
Will upload pics once its removed if needed
Will be available in around 2 weeks time
