griffsplace Posted November 18, 2017 Share Posted November 18, 2017 My steering pump is still very noisy after putting new fluid in, when you turn the steering wheel. I was considering buying one of the ones on eBay, considerably cheaper than genuine and even a refurbished. Anyone tried one? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 18, 2017 Share Posted November 18, 2017 Have you cleaned the reservoir out? Quote Link to comment Share on other sites More sharing options...
griffsplace Posted November 18, 2017 Author Share Posted November 18, 2017 yep I did got loads of black flakey bits out of it used some detergent and gave it a real good shake. I have pulled the pump and the new fluid looks pretty dirty already. The ebay pumps look like the correct item. Any idea how much a Toyota rebuild kit would be. Quote Link to comment Share on other sites More sharing options...
keron Posted November 18, 2017 Share Posted November 18, 2017 Those eBay ones are useless. I had 2 from 2 different suppliers and both failed in minutes of fitting them. The centre shaft was moving back and forward about 5 mm....shredded the belt too. Poor quality Chinese items..... It fitted ok though Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 18, 2017 Share Posted November 18, 2017 Get a Toyota rebuild kit for about 30 quid, do it yourself Quote Link to comment Share on other sites More sharing options...
griffsplace Posted November 18, 2017 Author Share Posted November 18, 2017 Ah brilliant, I will get in touch with my local Toyota for a rebuild kit. Need some new calliper bleed nipples as well. Quote Link to comment Share on other sites More sharing options...
griffsplace Posted November 20, 2017 Author Share Posted November 20, 2017 Started the strip down tonight, opened the pump up, its a bit dirty, but nothing obviously causing any problems, all the vanes are there in one piece, no really bad scoring etc, will go down to the dealers tomorrow to order the rebuild kit. Not convinced its going to make any difference. I do still need to check the flow control valve seals, but will do that tomorrow with compressed air as suggested. Quote Link to comment Share on other sites More sharing options...
griffsplace Posted November 20, 2017 Author Share Posted November 20, 2017 link to the video clip of the noise Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted November 20, 2017 Share Posted November 20, 2017 And you put ATF into the reservoir and not powersteering fluid yeah? Quote Link to comment Share on other sites More sharing options...
griffsplace Posted November 20, 2017 Author Share Posted November 20, 2017 yep this stuff Quote Link to comment Share on other sites More sharing options...
