Soopra Posted November 15, 2017 Share Posted November 15, 2017 Can anyone tell me whether my car will pass an MOT if I have harnesses in the front? I have no rear seats (no rear interior at all). Do I need to keep the seat belts? Thank you Link to comment Share on other sites More sharing options...
grahamc Posted November 15, 2017 Share Posted November 15, 2017 I have always kept the seat belts.... much easier and much more comfortable Link to comment Share on other sites More sharing options...
HarleyFDMD Posted November 15, 2017 Share Posted November 15, 2017 Providing the harnesses are mounted correctly you'll be fine. A really fussy Mot tester might write them as advisories as a non oem restraint system but they shouldnt fail Link to comment Share on other sites More sharing options...
Soopra Posted November 15, 2017 Author Share Posted November 15, 2017 Providing the harnesses are mounted correctly you'll be fine. A really fussy Mot tester might write them as advisories as a non oem restraint system but they shouldnt fail Brilliant thank you. Do you know the correct mounting points in a Supra? Link to comment Share on other sites More sharing options...
HarleyFDMD Posted November 15, 2017 Share Posted November 15, 2017 Well.. thats where it might fall into abit of a grey area. I would imagine the mounting points for the oem seat belts would suffice as far as the Mot was concerned.. however, in terms of "harnesses/motorsport/rollcages" etc etc the harnesses should be mounted at roughly a 90 degree angle to your shoulders, or atleast angled at 90 degrees with the aid of a harness bar. With the harnesses mounted into the rear seat belt positions they are angled incorrectly and can actually do more damage than good in an accident by pulling your shoulders downwards. With that being said though most road cars with harnesses seem to mount them this way anyway (but that doesnt make it right). I have harnesses in mine and have had a harnesses bar welded into my rollcage. The correct way to use a harness bar is like this: The harness is still mounted to the floor but in the event of an accident the downwards strain on your shoulders is deflected away by the bar. Some people mount there harneses directly to the bar.. this is also wrong unless otherwise stated by the manufacturer of the harness bar. I did alot of research on all of this while fitting my harnesses. Perhaps dont take everything i have said as gospel but just as a guide, i am only reciting what i have heard and read from other sources. Link to comment Share on other sites More sharing options...
Soopra Posted November 15, 2017 Author Share Posted November 15, 2017 That's brilliant, thank you. My harness is currently bolted to the floor where you rear strut brace is and is almost 90 degrees Link to comment Share on other sites More sharing options...
charlton Posted November 17, 2017 Share Posted November 17, 2017 I have fixed back bucket seats and harness and haven't had an issue in 2 or 3 MOT's. From what I read, the harness has to have a standard seatbelt buckle to be MOT compliant - it cannot be the twist release from the racing harnesses. I have these and they're attached to the rear strut brace Link to comment Share on other sites More sharing options...
Soopra Posted November 17, 2017 Author Share Posted November 17, 2017 cool, thank you. Looks hopeful as I have Sparco harnesses like the one above Link to comment Share on other sites More sharing options...
sideexitsupra Posted January 12, 2018 Share Posted January 12, 2018 I never had an issue with 5 point harness with twist release. But it was a very friendly tester, ahem. Link to comment Share on other sites More sharing options...
Richie_k83 Posted January 16, 2018 Share Posted January 16, 2018 I have never had an issue running harnesses. Providing your seats are completely removed, it should be an issue really. As for the correct mounting position of Harnesses, they shouldnt be at anymore the a 45 degree angle (according to my TRS Harness Paperwork). Less is preffered i guess. Worth mentioning that its not ideal to run Harnesses unless you have a rollcage. If you roll the car and are strapped to your seat, you'll end up with your head caved in Link to comment Share on other sites More sharing options...
