TB Developments EGR Delete Kit
TBDevelopments
TB Developments Supra 2JZ-GTE EGR Block Off Plates
A Must for UK Spec Supras to remove the EGR Which Will Stop Consumption of Hot Exhaust Gases Into The Intake Tract.
Kit Comes With Correct Thickness Stainless Steel Plates As Standard Valve. 8mm and 6mm, 2 Vacuum Pipe Blanking Plugs and Ties.
£25.00, International Customers Welcome
https://www.tbdevelopments.com/products/egr-removal-plates
Tim
TB Developments
  • 3 weeks later...
i can't say for sure if it fits the NA i'm afraid as it was built from a UK TT car. But if you know for sure then i'll happily send you a set.
It would yes as the EGR is a device to help emissions. But the idea of sucking exhaust gases back into the intake isn't great for performance. Plus the EGR has a habit of failing, pipe splitting etc. So this does away with that issue.
Tim
TB Developments
  • 3 months later...
