Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 ok we have a fair few bits off a few projects and cars we stripped for various reasons here at mb developments so time for a sort out precision 6466 gen 2 billet roller bearing turbo for sale removed from my own car/v band inlet and 3inch v band out let .82 rear housing/item is used but perfect working order no noises/no smoke or any signs of oil at all and only just removed so fully tested only thing worth mentioning is there is some minor marks on the intake blades minor and hasn't affect turbo in any way just worth mentioning/complete with billet -10 an oil return and correct size oil restrictor fitting all complete £1200 Turbo smart 44mm ultragate compact waste gate very little use only run up to 1.5 bar only very good con with sealing Collier and v band clamps does have sump tube for outlet v band but inlet band for manifolds is not included £280 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 V band 2jz tubular manifold with v band outlet to suit precision or tial v band housing with 44mm v band outlet also as pictured very good con hard to find in this fitting worked perfect on my build and flows very well no cracks or repairs etc £450 Samsonas bmw/universal short shift gear lever setup good con little use awesome bit of kit massively transforms the bmw gearbox gear change that we was running this year £300 Pmc 2jz to Bmw gearbox conversion kit only test fitted the adapter plate not actually run this one and same with the flywheel not actually been used flywheel has fitting kit still in bag bolts for adapter plate are included just not pictured. This is for the Bmw early 5 and 6 speed gearbox’s with the large input shaft £400 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 Sx 3 port adjustable fuel regular good working order fittings not included £100 1977 Celica custom drag rolling shell 8.50 spec cage in date/Hugh rear tubes arches custom 9inch ford end with diff /shafts/strange rear hubs/brakes/shocks/5link rear suspension set up/bladed rear sway bar/wildwood 4 pot front billet drag brake set up/bilstein inserts on oem dampers/modified steering rack position and mounts/engine mounts and subframe mounts/poly bushed tie rods/centre line front and rear drag wheels moroso 23x5.0/15 tyres/goodyear rear ^30x12.5/15 tyres/fully glazed with Perspex rear and front side windows/complete with brake lines and line lock /dash /steering column and rack and removable steering wheel/chute removable mount £5000 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 - - - Updated - - - Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 Precision twin scroll t4 turbo proven over 1000bhp...4inch v band ceramic coated exhaust housing / xs power twin waste gates/obx twin scroll manifold £1000 - - - Updated - - - Custom huge front mounted high flow intercooler £400 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 cast high volume inlet fully welded on to oem smoothed runners so no joins to worry about worked very well around 650bhp with no issues with high flow top feed fuel rail with welded on -10 feed and -6 return fitting included has been ran with bmw dbw throttle so throttle and cable mount may need to be altered £180 (DIPSTICK NOT INCLUDED) - - - Updated - - - Custom inlet with obx high flow fuel rail/q45 throttle body has been drilled for nos ports but we can weld up if not needed £350 uprated ls individual coilpack set with ht leads and bracket £100 Aeromotive 3 port fuel regulator £150 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 3bar map sensors B&m drag shifter £150 Direct port nitrous system with large bottle and heater twin billet bottle holder/solenoids/lines complete £600 - - - Updated - - - Trans temp gauge/oil pressure gauge/volt gauge/big tacho/boost/nos press gauge £300 2jz to syvecs s6gp custom engine wiring loom bit messy but did work 100% £500 Bosch wide bank lambda sensor £100 apexi 3port boost control solenoid £40 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 Panel less wiring switch panel £100 Diess chute £280 - - - Updated - - - Harwood fuel cell £80 Magnaflow fuel pump pro tuner series mp44701 2000bhp+ flow £400 Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 Rear custom rad set up with craig davis water flow kit large high flow kenlow fan set up braided feed hoses and aero fittings /over flow tank etc £500 - - - Updated - - - japan racing enkei rep wheels 18x10.5j rears et15 & 18x9j et35 front very little use no curbing or marks do have enkei stickers added hard to tell the from genuine ones nice and light in 5x114pcd fitting rears have some 285/35/18 r888 tyres these are on there limits might get a track day out them thou etc £500 Link to comment Share on other sites More sharing options...
WayneW Posted November 9, 2017 Share Posted November 9, 2017 What about the fitment of the wheels ? Rear one seem to have a too low et or ? Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 fitments on there 5x114pcd and et35 fronts and et15 rears so there staggered Link to comment Share on other sites More sharing options...
WayneW Posted November 9, 2017 Share Posted November 9, 2017 I m speaking of the arch fitment, any pics on a supra ? Link to comment Share on other sites More sharing options...
Style Posted November 9, 2017 Share Posted November 9, 2017 Are these manifolds for a GTE engine or a GE? Link to comment Share on other sites More sharing options...
Guest Mattybr5 Posted November 9, 2017 Share Posted November 9, 2017 Wayne Wheels wasn’t on a supra they bolt on but more than likely needing a wide arch kit in the rears Style Manifolds are from turbo spec motors Link to comment Share on other sites More sharing options...
